Widget Format Size Problem
I have a widget with two raws, one for EG shutters and one for OG shutters. But I am not able to get the standard size of a widget. What do I make wrong?
And additional how I can get the same writing like “Hoftor” to the left of my widget?
uid: my_Rollo_EG+OG_V1
tags: []
props:
  parameters:
    - context: item
      description: Rollershutter EG
      label: ItemEG
      required: false
      type: TEXT
    - context: item
      description: Rollershutter OG
      label: ItemOG
      required: false
      type: TEXT
timestamp: Dec 6, 2024, 11:31:46 AM
component: f7-card
  style:
slots:
  default:
    - component: f7-row
      slots:
        default:
          - component: f7-col
              style:
                margin-top: 5px
                width: 25%
            slots:
              default:
                - component: Label
                    style:
                      margin: 5px
                    text: Rollos EG
          - component: f7-col
              style:
                margin-top: 10px
                width: 15%
            slots:
              default:
                - component: oh-button
                    action: options
                    actionItem: =props.itemEG
                    actionOptions: 75=25%,50=50%,25=75%
                    fill: true
                    text: SET
          - component: f7-col
              style:
                margin: 5px
                width: 50%
            slots:
              default:
                - component: oh-rollershutter
                    item: =props.itemEG
    - component: f7-row
      slots:
        default:
          - component: f7-col
              style:
                margin-top: 5px
                width: 25%
            slots:
              default:
                - component: Label
                    style:
                      margin: 5px
                    text: Rollos OG
          - component: f7-col
              style:
                margin-top: 10px
                width: 15%
            slots:
              default:
                    action: options
                    actionItem: =props.itemOG
                    fill: true
                    text: SET
          - component: f7-col
              style:
                margin: 5px
                width: 50%
            slots:
              default:
                    item: =props.itemOG
The default card and cell widgets all have their height fixed at 120 pixels. So if you want you card to match that height then you just need to add height: 120px to the style of the card. This will probably have some other consequence with the position of the rows inside the card, so you will have to adjust those as well.
The widgets you are comparing to are oh-cell widgets. The user can add and configure these as simple single components, but they are, in fact, complex, compound elements. For example, the title element that you are comparing to is created by the following vue code:
      <f7-card-header class="cell-button card-opened-fade-out no-padding" v-show="!opened">
        <f7-list media-list>
          <f7-list-item v-else media-item :subtitle="config.subtitle" :footer="config.footer">
            <div slot="title" v-if="config.title" class="button-header display-flex">
              <oh-icon class="header-icon" v-if="!header && config.icon" :icon="config.icon" :color="config.iconColor" width="20" height="20" />
              <span class="header-text">{{ config.title }}</span>
            </div>
          </f7-list-item>
        </f7-list>
      </f7-card-header>
If you want to replicate that exactly, you would need to build up your own version by adding each of those extra components (and all of the OH specific css or classes that applies to each of those).
If you are 100% set on having this feature, it is possible, but time consuming and requires getting up to speed on reading the OH vue files to understand what you need to add and what you don’t.
The alternative is just to use the oh-cell as your base component instead. Then all the extra components you’ve added will be available when you click on the cell and expand it’s contents and you will be able to easily match the style and configuration of the other pieces with simple properties such as adding title: Your widget title to the oh-cell.
Thank you very much. I will try out your suggestions.
Best regards
Martin
I try out a lot of things, but I dont get what I want. I have problems with the structure of rows and columns and the size at the smartphone. Would you mind to helping me? I want two central rollershuter controls in one widge like the picture.
That would be very nice.
best regards,
Martin
I have the structure, but I dont able to use the whole place of the widget.
best regards
Martin
Unbenannt
uid: test
tags: []
props:
  parameters:
    - description: A text prop
      label: Prop 1
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Dec 13, 2024, 3:08:08 PM
component: f7-card
  style:
    background-color: "=props.bgcolor ? props.bgcolor : ''"
    box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
    height: 120px
    margin-left: 5px
    margin-right: 5px
    noShadow: false
    padding: 0px
slots:
  default:
    - component: f7-row
        style: {}
      slots:
        default:
          - component: f7-col
              style: {}
            slots:
              default:
                - component: Label
                    style: {}
                    text: EG
          - component: f7-col
              style: {}
            slots:
              default:
                - component: oh-link
                    actionCommand: UP
                    action: command
                    colorTheme: gray
                    iconF7: arrow_up_circle
                    iconSize: 25
          - component: f7-col
              style: {}
            slots:
              default:
                - component: Label
                    style: {}
                    text: EG
          - component: f7-col
              style: {}
            slots:
              default:
                    actionCommand: UP
                    action: command
                    colorTheme: gray
                    iconSize: 25
    - component: f7-row
        style: {}
      slots:
        default:
          - component: f7-col
              style: {}
            slots:
              default:
                    action: options
                    fill: fill
                    text: SET
          - component: f7-col
              style: {}
            slots:
              default:
                    actionCommand: STOP
                    action: command
                    iconF7: stop_circle
                    iconSize: 25
          - component: f7-col
              style: {}
            slots:
              default:
                    action: options
                    fill: fill
                    text: SET
          - component: f7-col
              style: {}
            slots:
              default:
                    actionCommand: STOP
                    action: command
                    iconF7: stop_circle
                    iconSize: 25
    - component: f7-row
        style: {}
      slots:
        default:
          - component: f7-col
              style: {}
            slots: {}
          - component: f7-col
              style: {}
            slots:
              default:
                    actionCommand: DOWN
                    action: command
                    colorTheme: gray
                    iconF7: arrow_down_circle
                    iconSize: 25
          - component: f7-col
              style: {}
            slots: {}
          - component: f7-col
              style: {}
            slots:
              default:
                    actionCommand: DOWN
                    action: command
                    colorTheme: gray
                    iconSize: 25
You are over complicating the structure of the widget. From the example image you posted, you want one row of four columns. You don’t need more containers than:
card
  row
    column
    column
    column
    column
Other considerations:
  1. You want to take up the whole card, so the row has to have size styles set to so that. For example, height and width (and box-sizing will make your life a little easier).
  2. For ease of use the column with the set buttons probably need to be a little wider than up/down columns. So, we’ll take advantage of the flex-box spacing that the f7-row provides and just give the wider columns a larger share of the flex distribution.
  3. You want the columns within the row to stack their child items vertically. So, we’ll give them their own flex display and make sure it’s turned to column spacing.
The end result looks like this:
Here’s the modified code (with some notes that match the above observations):
uid: test
tags: []
props:
  parameters:
      label: Prop 1
      required: false
      type: TEXT
    - context: item
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
component: f7-card
  style:
    height: 120px
    margin-left: 5px
    margin-right: 5px
    noShadow: false
    padding: 0
slots:
  default:
    #This is the main row
    - component: f7-row
        style:
          #Let's get it sized to take up the entire card
          box-sizing: border-box
          width: 100%
          height: 100%
          padding: 15px
          #Make sure that it won't try to put any columns in a second row
          flex-wrap: nowrap
          #Make the spacing of the rows pretty
          align-items: center
          justify-content: space-between
      slots:
        default:
          - component: f7-col
              style:
                #Give the column 50% more width than the default
                flex: 1.5
                #Make the column display its children in an auto-spaced vertical stack
                display: flex
                flex-direction: column
            slots:
              default:
                - component: Label
                    text: EG
                    action: options
                    fill: fill
                    text: SET
          - component: f7-col
              style:
                #Make sure that the buttons take up the whole vertical space
                height: 100%
                display: flex
            slots:
              default:
                    actionCommand: UP
                    action: command
                    colorTheme: gray
                    iconSize: 25
                    actionCommand: STOP
                    action: command
                    iconF7: stop_circle
                    iconSize: 25
                    actionCommand: DOWN
                    action: command
                    colorTheme: gray
                    iconSize: 25
          - component: f7-col
              style:
                flex: 1.5
                display: flex
            slots:
              default:
                - component: Label
                    text: EG
                    action: options
                    fill: fill
                    text: SET
          - component: f7-col
              style:
                height: 100%
                display: flex
            slots:
              default:
                    actionCommand: UP
                    action: command
                    colorTheme: gray
                    iconSize: 25
                    actionCommand: STOP
                    action: command
                    iconF7: stop_circle
                    iconSize: 25
                    actionCommand: DOWN
                    action: command
                    colorTheme: gray
                    iconSize: 25
Wow, this was very quick and absolutly what i want. Thank you very much. I spent more then 2 hours to this without the solution.
Have a nice christmas.
Best regards
Martin
