Widget-icon iconset="'custom-icon'" not working as expected
i wrote a widget which should display an icon based by it’s state.
<a class="dashboard-link" href="#/view/Batterie">
Batteriestatus: {{itemValue('Batterie_Problem')}}
<widget-icon iconset="'custom-icon'" icon="'batterie'" size="32" state="itemValue('Batterie_Problem')" />
</a>
This does only display the “default” icon.
As you can see i made sure i have an icon set, means default and all states i need.
What i am doing wrong here?
habpanel-widget
Built in iconpicker servlet wants image filenames all in lowercase
@rossko57 THANK YOU !!!
After changing the filenames to lowercase AND the transform file to lowercase “voll” and “leer” it is working now.
habpanel-widget_working
You should not need to transform the states. The iconpicker servlet does that for itself, i.e. it will look for blah-voll.svg for a state of VOLL (which is what gave you the problem) or Voll or VoLl
I use transform cause i get different state formats back, heating giving back on or off for battery warning, window sensors may give back 1 or 0 and i have some yes and no states coming back :slight_smile: To have it all clean i transform them to “voll” and “leer”
