hello together,
working on My habpanel im facing another Problem with A widget. i reused an available calendar widget and wanted to add A Filter if there are not enough Events in the next time. then the widget always showed an ugly “UNDEF”.
So i tried ng-hide at different places but result is always that it works until i refresh the Browser.
any one know why?
<div class="calendar">
<div class="calendar-header">{{config.CalendarHeader}}</div>
<div ng-repeat-start="n in [].constructor(5) track by $index">
<div ng-if="(config.CalendarGlobalNumberOfEvents > $index) && ((config['CalendarEvent'+ ($index+1)+'StartDateTime'])!==UNDEF) && ((config['CalendarEvent'+ ($index+1)+'StartDateTime'])!==NULL)" class="calendar-row"
ng-hide="{{itemValue(startTime)}}==UNDEF || {{itemValue(startTime)}}==NULL" class="ng-hide"
ng-init="endTime =config['CalendarEvent'+ ($index+1)+'EndDateTime'];
startTime=config['CalendarEvent'+ ($index+1)+'StartDateTime'];
summary=config['CalendarEvent'+ ($index+1)+'Summary'];
location=config['CalendarEvent'+ ($index+1)+'Location'];">
<div class="calendar-col-1">
<div ng-if="(config.CalendarGlobalShowDate)" class="event-date"> {{itemValue(startTime) | date:'dd. MMM'}}</div>
<div ng-if="(config.CalendarGlobalShowDay)" class="event-day"> {{itemValue(startTime) | date:'EEE'}}</div>
</div>
<div class="calendar-col-2">
<div class="event-summary">
<span ng-if="(config.CalendarGlobalShowSummary)"> {{itemValue(summary)}}</span>
</div>
<div class="event-time">
<span ng-if="(config.CalendarGlobalShowTime) && ((itemValue(startTime) | date:'dd.MM.yyyy') == (itemValue(endTime) | date:'dd.MM.yyyy'))"> {{itemValue(startTime) | date:'HH:mm'}}</span>
<span ng-if="(config.CalendarGlobalShowTime) && ((itemValue(startTime) | date:'dd.MM.yyyy') == (itemValue(endTime) | date:'dd.MM.yyyy'))"> - </span>
<span ng-if="(config.CalendarGlobalShowTime) && ((itemValue(startTime) | date:'dd.MM.yyyy') == (itemValue(endTime) | date:'dd.MM.yyyy'))"> {{itemValue(endTime) | date:'HH:mm'}}</span>
</div>
<div class="event-location">
<span ng-if="(config.CalendarGlobalShowLocation)"> {{itemValue(location)}}</span>
</div>
</div>
</div>
</div>
<div ng-repeat-end ng-if="(config.CalendarGlobalNumberOfEvents > $index +1)">
<hr class="event-divider"/>
</div>
</div>
