I am struggling to create two very simplistic buttons that are going to increase or decrease the value of my hearting thermostat.
The reason that I believe is causing the issue is the item “zwave_device_98a9193a_node8_thermostat_setpoint_heating” that is not a number only it is a number and degree Celsius after. - so 22 *C will be the output.
If I use this code:
ng-click=“sendCmd(‘zwave_device_98a9193a_node8_thermostat_setpoint_heating’, ‘24’)”
It will work perfectly and the value will be set at 24.
But if i try this one:
ng-click=“sendCmd(‘zwave_device_98a9193a_node8_thermostat_setpoint_heating’, ‘itemValue(‘zwave_device_98a9193a_node8_thermostat_setpoint_heating’) * 1 + 0.5’)”
it will not work because i bealive that the code will send this to the controller: (let’s assume that the actual value is 22)
22*C + 0.5 … and therefore it cannot sum up to 22.5 …
How can i fix this ??
Basicly i need to read the value - just the integer not the entire format …
Many thanks
