Widget: using string within itemValue
Hi Guys,
i try to use a string as part of my itemValue extract.
See:
Type: Item
Default value: Kueche_Timer_Ending
Type: String
Code:
{{itemValue(config.timerending)}} -> 2018-01-03 11:06:19
{{itemValue(‘Kueche_Timer_Ending’)}} -> 2018-01-03 11:06:19
itemValue(’{{config.room}}_Timer_Ending’) -> itemValue(‘Kueche_Timer_Ending’)
{{itemValue(’{{config.room}}_Timer_Ending’)}} -> will cause all values to fail and simply print out e.g. {{itemValue(’{{config.room}}_Timer_Ending’)}}
How can i make the string part of my itemValue to get the correct output?`
Andreas
Just one other idea,
would it be possible somehow to create a string setting with ID: room
and then create an Item with ID: timerending and the default value would be then: {{room}}_Timer_Ending or so?
Andreas
What’s inside {{ }} is an expression so you can’t interpolate strings, rather should use the standard Javascript syntax:
{{itemState(config.room + '_Timer_Ending')}}
https://www.w3schools.com/angular/angular_expressions.asp
Hello Yannick,
i guess i said it once a while ago, i will say it again: YOU ARE THE MAN!
Thank you very much. Seeing this now makes absolute sense and i am a bit grumpy about not finding this out myself.
It makes all my widgets now much easier for me.
Andi
