no need to clean the entire system. just OH2
we can also continue the effort to troubleshoot the existing installation if you want but it would be easier to re-install it
You can do a backup of the user data files, reinstall via openhabian, then restore the userdata
@Dim @Branden_Smale Hi again! Itās me from another account as Iām limited for being new! I did a fresh installation. I reinstalled openhab, everything is fine BUT the WiFi Led binding. It just turns OpenHAB crazy and throws this error:
2018-11-09 13:26:27.405 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-wifiled': Error:
Resource mvn:org.openhab.binding/org.openhab.binding.wifiled/2.3.0 does not contain a manifest
Keep in mind that I did a fresh install. Everything works BUT WiFi Led Binding. Installed from Paper UI. This is a mistery. Maybe thereās something wrong with the binding jar?
I finally solved the problem. It looks like OpenHABās documentationās installation guideās build comes with a broken WiFi LED Binding. ĀæHow did I solved it? I took the .jar and the .jar.sha1 from the OpenHAB installation that I had previously on my Windows PC and I moved it to linux. Then I installed the binding from Paper UI. This solved the problem and I donāt have any errors anymore. Everything working fine. The linux OpenHAB didnāt had the sha1 file.
The problem: It looks like the .jar is outdated (there was a bug with this binding some months ago) and someway the bug appeared again even if I did a clean installation.
The solution: Download the fixed files from here. Extrac the .zip file and replace the whole folder in /var/lib/openhab2/tmp/kar/openhab-addons-2.3.0/org/openhab/binding/org.openhab.binding.wifiled
The folder to replace is 2.3.0.
No, it doesnāt
where did you place it?
after installation of the binding, you had the jar but not the jar.sha1?
I did a fresh install and it didnāt workā¦ So I donāt know why the problem was solved with my solution.
I moved the files to /var/lib/openhab2/tmp/kar/openhab-addons-2.3.0/org/openhab/binding/org.openhab.binding.wifiled
After moving the 2 files, I installed the WiFi LED Binding from Paper UI and it started working as good as in Windows.
Need or not, itās working now. I compared the .jar I had in windows and the .jar I had in linux and they had a different file size.
Exactly.
this is the problem. somehow you had the older broken jar (or you never cleaned up tmp and cache properlyā¦?)
But I can not understand how I had the old .jar if the raspberry has 2 days and I did a fresh install using the documentationās guide
thatās strangeā¦
i will try to replicate this on a test machine
when the issue was resolved, I tested the corrected binding and it was working fineā¦
At least in my Windows machine was working well. Thanks for your help!
I cannot replicate this
tested OH 2.3.0 on linux and the WiFi LED binding gets installed without any problems (using online repo)
with the binding installed, nothing exists in /var/lib/openhab2/tmp/kar/openhab-addons-2.3.0/org/openhab/binding/org.openhab.binding.wifiled
this is related to the openhab-addons-2.3.0.kar file (which has another major issue, not related to the WiFiLED binding)
the binding is stored in /var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.wifiled
(jar and sha1)
so you used somehow the openhab-addons-2.3.0.kar file ā¦ (and you forgot to mention this until now :))
I even removed manually the .jar.sha1 file and the system works as expected
binding remains installed, no errors being logged
