I’m having some trouble getting these 3 new Lepro GU10 RGB Bulbs working…
my openHAB version is 3.1.0 release build
I found this post …it describes the parameters to add this bulbs to openhab.
After successfully detecting the ip-adresses of each bulb I added textual configuration files with the recommended settings from the linked post and my detected ip’s.
Now OH shows the 3 things ONLINE
and the items are shown in MainUI and I also added them to my old fashioned sitemap file for testing purposes. The channels are shown as linked
to the items.
My problem is, everything is shown and working inside openHAB, but the bulbs won’t react to any change made there… if I use the lampUX android app everything is fine…
Any thoughts on that to avoid me pulling my hair out? maybe any errors in the things configuration from the linked post?
my things file looks like this:
Thing wifiled:wifiled:708976xxxx10 [ ip="192.168.xxx.xxx", port=6668, pollingPeriod=30, protocol="LD382A", driver="FADING", fadeDurationInMs=1000, fadeSteps=100 ]
Thing wifiled:wifiled:708976xxxx99 [ ip="192.168.xxx.xxx", port=6668, pollingPeriod=30, protocol="LD382A", driver="FADING", fadeDurationInMs=1000, fadeSteps=100 ]
Thing wifiled:wifiled:708976xxxx89 [ ip="192.168.xxx.xxx", port=6668, pollingPeriod=30, protocol="LD382A", driver="FADING", fadeDurationInMs=1000, fadeSteps=100 ]
my items file:
Switch Smartbulb01Power "Power" (Light) {channel="wifiled:wifiled:708976xxxx10:power"}
Dimmer Smartbulb01White "White" (Light) {channel="wifiled:wifiled:708976xxxx10:white"}
Color Smartbulb01Color "Color" (Light) {channel="wifiled:wifiled:708976xxxx10:color"}
Dimmer Smartbulb01Speed "Speed_LED" (Light) {channel="wifiled:wifiled:708976xxxx10:programSpeed"}
Switch Smartbulb02Power "Power" (Light) {channel="wifiled:wifiled:708976xxxx99:power"}
Dimmer Smartbulb02White "White" (Light) {channel="wifiled:wifiled:708976xxxx99:white"}
Color Smartbulb02Color "Color" (Light) {channel="wifiled:wifiled:708976xxxx99:color"}
Dimmer Smartbulb02Speed "Speed_LED" (Light) {channel="wifiled:wifiled:708976xxxx99:programSpeed"}
Switch Smartbulb03Power "Power" (Light) {channel="wifiled:wifiled:708976xxxx89:power"}
Dimmer Smartbulb03White "White" (Light) {channel="wifiled:wifiled:708976xxxx89:white"}
Color Smartbulb03Color "Color" (Light) {channel="wifiled:wifiled:708976xxxx89:color"}
Dimmer Smartbulb03Speed "Speed_LED" (Light) {channel="wifiled:wifiled:708976xxxx89:programSpeed"}
thanks
Dan
