I can strongly NOT recommend the heatmiser wifi thermostats. Look nice enough, but feeble wifi connectivity, awful interface and poor security.
Not what you asked, but, incidentally, there are other threads on zwave thermostats which reach the general conclusion that they are all rather rubbish!
I like my ecobee. It’s the original Smart which is no longer available. They do still sell the Smart Si (https://shop.ecobee.com/products/smart-si) which is not a learning thermostat.
All HVAC stuff depends on your location, you should meantion at least whether you’re in U.S. or Europe …
Not WiFi but 868MHz radio, you could look at the Danfoss zwave based series or the eQ-3 MAX! series. The latter come with a cloud based remote access, but you don’t need to use it. There’s an openHAB binding for it.
Right! I’m in Canada, so we should have the same hardware that’s available in the States.
Sounds like it could be close to what I’m looking for. Looking at the binding, it requires an account with the ecobee cloud server. Is that only for the initial setup? Or does it still run through the cloud, even after a developer account is set up? It’s sounding like I might just have to bite the bullet on that one.
The only access to Ecobee thermostats is via their Internet-based API. If you have a reliable Internet connection, my experience is that you won’t have problems — their service has been very reliable for me over years. Ecobee now has an ecobee3 Lite thermostat, still with native HomeKit support but no remote sensors. The full ecobee3 supports wireless sensors to use temp and occupancy to dynamically adjust comfort to where people are in the home. Their other older model thermostats are solid devices as well (I also have a Smart Si that never has a problem). And Ecobee is a Toronto-based company.
Why don’t you just take Z-wave temperature sensor, like one from Aotec 6-in-1 and connect it to OpenHAB? Then use rules to create thermostat control and adjust it via Sitemap. If necessary add simple tablet on the wall to see current temp and adjust it from there. In total this would cost you 60+70=130 $.
I’d recommend getting either Ecobee3 Lite, Ecobee3 or Ecobee4. These thermostats are top-notch devices that offer the best features on the market. Nest is way behind Ecobee and today, Nest can’t offer features anywhere close to the latter.
I need WIFI thermostat system which capable switch 220 volt,
something like Devi Smart but with support in openHAB.
similar to eQ-3 MAX!, but it has only radiator head, instead
I need WIFI thermostst + relay (220 volt) box.
Electrically devireg Smart looks like:
I can connect and switch any load (electrical radiator, electrical heating floor, heathing water floor thermoelectric Actuator, e.t.c - any 220 volt load)
But it’s not mandatory to have all this in one box, it will be good to have WIFI thermostat and corresponding WIFI relay box separately.
@StNick, a Sonoff TH16 will provide you switching capacity of 220v at up to 16A, as well as the ability to attach a temperature/humidity sensor, and easily-available open-source firmware available for it (such as Tasmota) to allow feedback and control via openHAB.
This doesn’t have any display or tactile input, but if you purely need to switch a 16A load, and sense the room temperature, this should do the job for you (and is something I am considering using as a basis for my new house)
You can also deploy a 2nd device as an actuator to operate the 220VAC. Thermostat triggers OH, OH triggers actuator.
There’s also 230VAC sockets to be part of the MAX! series, dunno if but possibly the thermostats can directly switch them (without OH inbetween).
I was also looking desperately for such Wifi thermostats. But so far I didn’t find something proper. I don’t want cloud, I like a control device with display (no Sonoffs) and I need at least 4 of them, so commercial products quickly become quite expensive.
My current solution / idea is:
Hardware:
Max! Wall thermostats (30 EUR each)
Max! “Gateway” (Homegear on RPI Zero, CC1101 868)
Actuator: Ubiquity Mpower pro (Relay to control existing valves for underfloor heating)
Software:
Solely controlled by Max! Wall thermostats (Send current and target temp, May receives schedule and target temp via MQTT)
The gateway translates MAX! 868 Rf into MQTT commands
Mpower implements the switching and hysteresis (listenes via MQTT, reports the state via MQTT)
Openhab is only monitoring and can potentially feed the Max! Wall thermostats with new schedules or target temperatures
So I have a solid, inexpensive and open 4-room thermostat solution for ~200 EUR.
So you want to use underfloor heating valves on radiators ? Do you have this working already ?
I, too, am using it on my underfloor and ever thought of applying that to a radiator, too, but so far I didn’t dare.
Not sure what you mean.
I have the devices linked below.
They will be controlled by the 230V Socket outputs of the mPower.
Currently I have only the software running. (no real switching)
This is to test the logic and reliability of the device chain (Thermostat -> homegear -> MQTT broker -> mPower)
Implementation on mPower is shell script based.
I have it in production now since some weeks. Works stable!
Max wall thermostat reports target and current temp directly to the switch actor via MQTT (mPower)
Openhab is just “listening” and recording/persisting.
@OP what are you trying to accomplish? You said you didnt want a truly smart thermostat. If you just want to record temps, a dht22 and an esp8266-01 (abot $2 each from AliExpress) should work fine. If you want to actually control the HVAC, just a few relays with an esp8266:
