2017-01-24 12:08:55.646 [WARN ] [ore.service.AbstractWatchQueueReader] - Could not process config file '.#addons.cfg': java.io.FileNotFoundException: /etc/openhab2/services/.#addons.cfg (Datei oder
Verzeichnis nicht gefunden)
If I understand the comment in the addons.cfg correct, there should automatically be cfg files created for both bindings.
But I donât even see, if the bindings got installed.
When changing the config to just âonkyoâ, I get this:
2017-01-24 12:11:42.917 [WARN ] [ore.service.AbstractWatchQueueReader] - Could not process config file '.#addons.cfg': java.io.FileNotFoundException: /etc/openhab2/services/.#addons.cfg (Datei oder
2017-01-24 12:12:08.198 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-netatmo'
2017-01-24 12:12:14.095 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-kodi'
Now I got a few questions:
Shouldnât there be some log like âInstalled âopenhab-binding-âŠââ?
Should the cfg files be created manually or automatically?
What does âCould not process config file â.#addons.cfgââ mean?
This file does not exist.
It looks like you may have a cached version of addons.cfg that may be causing OH some problems. What editor do you use?
Look to see if you have .#addons.cfg file using ls -a in the services folder. If it exists delete it. See if that helps. You file should be just addons.cfg but lots of text editors will save versions of the file as you type like this and if your editor crashes you can recover your unsaved changes. But if you donât clean up these cache files they stick around. And since this one starts with a â.â it doesnât show up in a normal ls and since it ends in â.cfgâ OH is trying to load it.
You might need to restart.
Yes, when a binding gets installed a default .cfg file should be created. There are a few bindings that have no config parameters in which case no .cfg file is created. I also donât think the .cfg files for BasicUI and ClassicUI are created automatically.
There was recently a bug where a failure to parse a cfg file caused OH to no longer load any files. If that hasnât been fixed then these cache files could be the source of your problems.
Iâm pretty certain one or both of those bindings do generate .cfg files (could be wrong, I donât use either of them).
Look in PaperUI or the Karaf console to see if they are indeed listed as installed.
ESH/OH2 bindings usually do not require any cfg files, therefore they wonât create any of those. What would you expect to configure in there for Netatmo and Kodi?
I expect to configure ip, user/password fpr kodi or netatmo:refreshtoken etc.
Just like the old openhab.cfg.
I know I can configure this via PaperUI, but I wanted to try to configure everything manually via config files.
This seems to be better organized for me and the better way to backup and migrate my config later.
When you install a binding through PaperUI it will automatically create a .cfg file in conf/services/ for the appropriate binding. Inside these files are a predefined set of variables which are required for the binding to operate.
This is definitely not happening for many bindings.
I cannot even find an example for the netatmo.cfg.
The quote you cited from the documentation should be changed to indicate that add-ons that have their own configuration should install a default .cfg file so they can be configured via files. Any OH2/ESH binding that cannot be configured without the UI, only for lack of a .cfg file, should be fixed. Could you open issues?
Regarding 1.x add-ons, only the subset that are known to work under OH2 install a default .cfg file if they need one and a feature has been defined for them (like openhab-binding-mqtt1). If a feature has been added for them, they can be installed via OH2âs add-on installation capabilities. Other 1.x add-ons that are still handled as JAR files wonât affect the existence of any services/xxx.cfg file, so you might have to create your own manually until features are defined for them.
The 1.x add-on documentation is in the process of being upgraded to show instructions relevant for OH2 users. As long as this link remains valid, you can browse to the add-onsâ README.md files to see the documentation upgrade in progress. Comments welcome!
Anyone please correct me if Iâve misstated anything above. Thanks!
Should I create separate issues for each binding with this problems?
Should I create separate issues for âmissing cfg fileâ and âmissing dosumentationâ?
