I discovered yesterday that my SD card ‘silently’ corrupted and I’m slowly recovering including many packages reinstall. Through debsums I found that some files from OH2 are suspicious
and what worries me are the 2 first lines. First one is xml but still I can’t list it with ‘more’ (seems to have some binary content or corrupted), jar I can’t assess.
I was thinking about reinstalling the whole OH but I don’t know whether this will override any existing config (items, logging, etc). Installation is pretty wide now and eventhough I’m doing daily backup I don’t want to restore configs manually.
Thanks in advance for all advises.
Benjy, thanks. Regarding reinstall method I am using the one listed by you. I am not afraid of config under /etc but mostly about something in other places (e.g. java logging, etc). I guess this will be changed, won’t it?
when it comes to backups - no, I’m using rsync for broader backup (OH2 including).
Anything created by openHAB dynamically is registered as a configuration file. So the logs stored in /var/log/openhab2, and anything in /var/lib/openhab2 will also be kept on a reinstall. Hope that helps?
The files in /var/lib/openhab2/etc is a special case, the majority of files here are replaced but this shouldn’t affect anything noticeable.
