I’ve tried both OH and HA. In the end HA just frustrated me because I couldn’t configure the rules exactly like I wanted to. I also wasn’t able to configure the UI as much as I wanted to. For example to control my AV receiver I would have to use a media player “widget” (or whatever they are called). But that doesn’t have the controls that I wanted. With OH I could very easily just add customized buttons that I need and do what I want.
My main issue with OH is pretty much the multiple choices of UI with very different concepts that don’t work together. But at least that is getting a bit better with OH3… although not as much as one would like. Things like MQTT are also a bit weird to set up and the concept of items/things could probably be a bit simplified (even though it often works quite nicely). Persistence is also something that is way too complicated for what is actually needed in most of the cases.
