Windows 10 home V1903 will not complete initial startup
  • Platform information: Windows 10 Home
    • Hardware: CPUArchitecture/RAM/storage
    • OS: _what OS is used and which version_Windows 10 V 1903
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version: 2.4.0 (stable)
  • Issue of the topic: please be detailed explaining your issue Newbie to this, not overly literate with code etc, but want to learn. I have installed this software on two windows 10 machines, and when I call “startup” I am asked if I want to allow changes to my computer (yes) and then change of registry (yes) then a dos dindow opens, and flashes up a list of comments and commands, that I think includes words like “unable to edit registry” before closing after a very short period of time. No further response.
    Help!
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
What Java runtime are you using? Only Java 8 is supported not the newer Java 11.
How are you attempting to install OpenHAB? The normal official install on Windows is done manually.
I do not know of any official automated installer for Windows.
