Windows PC remote control (Shutdown, …)
this one focuses on how to configure the MQTT binding for openHAB and doesn’t really cover the management of the Broker itself
to learn how to administrate the Mosquitto MQTT Broker, you would need to go to more destinations like:
https://www.mosquitto.org/man/mosquitto-conf-5.html
etc
@Dim I think I have added the Mosquitto with auth setup. After playing anround from the 1st post.
1:can not use my watering system on app or http (basic UL).
2: use mqttFX to test my watering system. It will not connect to my server.
What should I try next…
Or I have to start from the start and reinstall openhabian.
@Dim I just went into config and reinstalled mqtt. Still didn’t work. And reinstall mqtt on Paper UI too. mqtt had a new mqtt binding from snapshot 2.4.
Still didn’t work.
don’t use the new MQTT v2 version yet. It is still being developed.
Use the legacy MQTT v1.
Is your mosquitto up and running?
I’m just uninstalland mqtt v 2
No MQTT not running.
It will not even connect using MQTT.fx.
You know MQTT.fx yes.
Things I tryed was reinstalling mosquito in openhabian-confin
It’s all good guy’s will just restarted even things from the start.
