I gladly do. But it has to wait until to morrow.
Looks good (on first sight).
Thanks for the effort.
@ namraccr
I have tested the binding on a Windows 10 PC.
Ping now works correctly.
Thanks.
Can you give me some hints about the network.cfg file (name and folder) and the arping.exe file?
OK, I found (a part of) the solution for the config file myself.
For a normal installation: The parameters file for the network binding can be set with the PaperUI. The parameters are then written in a ânetwork.configâ file. On Windows this file is in the folder â.\userdata\config\bindingâ. This file can be edited with an editor like Notepad++.
(During testing with Eclipse I did not see a network.config (or any *.config file). With the PaperUI you can set the parameters, but perhaps they are not saved in a file.
Somehow a network.cfg file inside .\conf\services get processed (logfile: âProcessing config file ânetwork.cfgââ) but I did not find out what is done with its content.)
PaperUI saves the binding configs down in userdata/config/org/openhab. You should not edit these files directly, but that is where they get saved.
@rlkoshak: you are right of course. (But for now it is the only way I can solve it).
I have done so. See https://github.com/openhab/openhab2-addons/issues/3502.
