Homematic binding still offline on Windows Server 2016. Java is running and start.bat starts without problems.
Is there anybody, who installed openhab on Windows Server 2016?
Did you follow these instructions for installing openhab on Windows ?
http://docs.openhab.org/installation/windows.html
If you have validated your install is correct you’ll need to provide logs for the community to help you
–> C:\openHAB2\userdata\logs
Also, you should rename your post beyond “Windows Server 2016” to something like “Homematic device binding issue on Windows 2016” so people can find it easily if they have the same problem.
