Currently I use Caldav for this
Me too, I thought that would be a good alternative though
I’ve created the PR.
Please add any further comments and edits there.
How to use holiday_descriptions.properties ?
/Mike
@mashborn Did you ever get the xml file to be found? I’m running into the same issue on OH 2.5 stable (openhabian).
use
getHolidayDescription(holiday name)
Jollyday defines a mapping between the holiday name and a description. This will return the description based on the holiday name returned by getBankHolidayName
I’m trying to make it work
but I haven’t succeeded
/etc/openhab2/services/Holidays_gr.xml
<?xml version="1.0" encoding="UTF-8"?>
<tns:Configuration hierarchy="gr" description="Greece"
xmlns:tns="http://www.example.org/Holiday" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.example.org/Holiday /Holiday.xsd">
<tns:Holidays>
<tns:Fixed month="JANUARY" day="1" descriptionPropertiesKey="NEW_YEAR"/>
<tns:Fixed month="JANUARY" day="6" descriptionPropertiesKey="THEOPHANY"/>
<tns:Fixed month="JANUARY" day="12" descriptionPropertiesKey="CHRIS_BIRTHDAY"/>
<tns:Fixed month="JANUARY" day="20" descriptionPropertiesKey="Chris_test"/>
<tns:Fixed month="JANUARY" day="30" descriptionPropertiesKey="THREE_HIERARCHS"/>
<tns:Fixed month="FEBRUARY" day="25" descriptionPropertiesKey="February_25"/>
<tns:Fixed month="FEBRUARY" day="26" descriptionPropertiesKey="February_26"/>
<tns:Fixed month="MARCH" day="6" descriptionPropertiesKey="GEORGE_BIRTHDAY"/>
<tns:Fixed month="MARCH" day="25" descriptionPropertiesKey="ANNUNCIATION"/>
<tns:Fixed month="MAY" day="1" descriptionPropertiesKey="LABOUR_DAY"/>
<tns:Fixed month="MAY" day="4" descriptionPropertiesKey="KONSTANTINE_BIRTHDAY"/>
<tns:Fixed month="MAY" day="6" descriptionPropertiesKey="OLGA_BIRTHDAY"/>
<tns:Fixed month="AUGUST" day="15" descriptionPropertiesKey="ASSUMPTION_DAY"/>
<tns:Fixed month="OCTOBER" day="28" descriptionPropertiesKey="OCHI"/>
<tns:Fixed month="DECEMBER" day="25" descriptionPropertiesKey="CHRSITMAS"/>
<tns:Fixed month="DECEMBER" day="26" descriptionPropertiesKey="STEPHENS"/>
<tns:ChristianHoliday type="EASTER" chronology="JULIAN"/>
<tns:ChristianHoliday type="CLEAN_MONDAY"
chronology="JULIAN" />
<tns:ChristianHoliday type="GOOD_FRIDAY"
<tns:ChristianHoliday type="EASTER_MONDAY"
<tns:ChristianHoliday type="WHIT_MONDAY"
</tns:Holidays>
</tns:Configuration>
items
Switch TestEphemeris “Test Switch”
rules
val filename = "Ephemeris"
rule "Ephemeris started rule"
Item TestEphemeris changed
if (Ephemeris.isBankHoliday(0,"/etc/openhab2/services/Holidays_gr.xml") ) {
logInfo(filename,"February 25") // not working
if ( Ephemeris.isBankHoliday(1,"/etc/openhab2/services/Holidays_gr.xml") ) {
logInfo(filename,"February 26") // not working
if (!isWeekend(5)) {
logInfo(filename,"Ημέρα της εβδομάδας") // OK
if (isWeekend(4)) {
logInfo(filename,"Αύριο είναι το Σαββατοκύριακο") // OK
if (isInDayset("school",0))// deytera me paraskeuh
logInfo(filename,"Υπάρχει σχολείο σήμερα") // OK
i’m trying
but not work
thanks
Hi @jcosta46,
Unfortunately exactly the isBankHoliday(<offset>, <file>)
action is broken in OH 2.5.x and will probably not working before OH 3.0 - even if it is already fixed in our code base (see https://github.com/openhab/openhab-core/issues/1374).
A small workaround is to use isBankHoliday(<datetime>, <file>)
and set ZonedDateTime.now().plusDays(<offset>)
for <datetime>
I think we should add a note to the docs.
I added this to my ephemeris.cfg
org.openhab.ephemeris:dayset-weekend = [SATURDAY,SUNDAY]
org.openhab.ephemeris:dayset-school = [MONDAY,TUESDAY,WEDNESDAY,THURSDAY,FRIDAY]
org.openhab.ephemeris:country = [DE]
This is how my config looks under PaperUI:
I have no idea how to fix this. Whatever I do either in PaperUi or in ephemeris.cfg - the result is broken like in the screenshot.
thanks
could you help me
val filename = “Ephemeris”
var Number datetime = ZonedDateTime.now().plusDays(1)
var file = "/etc/openhab2/services/Holidays_gr.xml"
if (Ephemeris.isBankHoliday(datetime,file) ) {
if (isWeekend(4)) {
I don’t know how to write it.
I get that
2020-02-26 01:11:48.292 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Ephemeris started rule': The name 'ZonedDateTime' cannot be resolved to an item or type; line 61, column 29, length 13
Try
new DateTimeType().zonedDateTime.now().plusDays(1)
thanks
but I couldn’t make it work
i have tried this
var datetime = new DateTimeType().zonedDateTime.now().plusDays(1)
if (Ephemeris.isBankHoliday(new DateTimeType().zonedDateTime.now().plusDays(1),"/etc/openhab2/services/Holidays_gr.xml") ) {
logInfo(filename,"February 27") // not working
if (isBankHoliday(new DateTimeType().zonedDateTime.now().plusDays(1),"/etc/openhab2/services/Holidays_gr.xml") ) {
if ( Ephemeris.isBankHoliday(datetime,file) ) {
if (isBankHoliday(datetime,file) ) {
if ( Ephemeris.isBankHoliday(datetime) ) {
if (isWeekend(4)) {
Errors in the log?
@rlkoshak nothing Errors in the log
I had to do
sudo systemctl restart openhab2.service
now it works
thanks
var datetime = new DateTimeType().zonedDateTime.now().plusDays(0)
logInfo(filename,"February 28") // ok
if (isWeekend()) {
Hi all,
I’m trying to lookup some “holiday” with proper translation, but fail and hope you can advise or help
Unfortunately I have no idea how to debug further as it’s my names are simply not looked up.
My entry in *.xml
<tns:FixedWeekdayRelativeToFixed which="FIRST" weekday="SUNDAY" when="BEFORE" descriptionPropertiesKey="FOURTH_ADVENT" localizedType="OFFICIAL_HOLIDAY"> <tns:day month="DECEMBER" day="25"/> </tns:FixedWeekdayRelativeToFixed>
Entry to holiday_descriptions_de.properties
holiday.description.FOURTH_ADVENT = 4. Advent
This seems to be equal to the other entries.
So FOURTH_ADVENT is returned properly when using
logInfo("Test", "Vierter {}", Ephemeris.getBankHolidayName((new DateTimeType("2021-12-2019").zonedDateTime), '<myPath>/holidays_de.xml'))
But I didn’t get value from
logInfo("Test", "vorher: {} und nachher: {}", Ephemeris.getBankHolidayName((new DateTimeType("2020-12-20").zonedDateTime), '<myPath>/holidays_de.xml'), Ephemeris.getHolidayDescription(Ephemeris.getBankHolidayName((new DateTimeType("2020-12-20").zonedDateTime), '<myPathY/holidays_de.xml')))
Returns
20:27:42.667 [INFO ] [g.eclipse.smarthome.model.script.Test] - vorher: FOURTH_ADVENT und nachher: undefined
Hope this helps?
works fine - thank you!
Could you please also correct the documentation at
(https://www.openhab.org/docs/configuration/actions.html#ephemeris)
It still says
…This action is broken in OH 2.5.x. Use getNextBankHoliday(, ) instead by replacing with ZonedDateTime.now().plusDays()
It’s easy, just click on the link at the bottom of the page, this is a community driven project.
Thanks for the hint - done
Hi all,
I have just migrated to openHAB 3.1.0 Snapshop, but still have issue to get personal SpecialDays translated properly (Reported here while on OH2.x)
I have added my special days to holiday_descriptions_de.properties which is stored along with the other xml in services folder. Special days added to specialdays.xml are reconized, just not translated properly :-/
Does anyone have same issue on OH3?
Regards
Joerg
A question about daysets:
For me, the trash is only emptied every second Monday.
Is it possible to specify in ephemeris.cfg
that dayset-trash
applies only every second Monday?
