my central heating system occasionally fails, indicated by the error lamp. Can anybody recommend a wireless optical sensor with OpenHAB connectivity which can detect the error state by supervising this lamp?
Thanks!
Thanks!
Hi do you want to go. the diy way or The turn key way ?
I would prefer a turn key solution.
If it was diy you had some options that you could have used. but turn key I am not so sure what is available on the market.
I’d check if there’s also a output pin to signal the error. Most heaters have it. Then you can attach any wireless switch such as ZWave devices (if you already own) or a Sonoff or Shelly WiFi switch.
That can also work.
Thanks @mstormi and @allen. I just checked the circuit diagram of the 24y old heater but could not identify such an output pin. I will try further. I still think a simple llight sensor supervising the error lamp would be a nice and electrically-isolated solution for this class of tasks.
If it was me I would look I using a esp8266 with a LDR and mqtt . then you always have the option to add some more sensors or even controls to the zone around the heating system.
