Platform information:
Ip = 192.168.178.21
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.32-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Uptime = 0 day(s). 20:58:49
CPU Usage = 0.25% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 0.16, 5m: 0.07, 15m: 0.02
Memory = Free: 0.12GB (13%), Used: 0.82GB (87%), Total: 0.95GB
Swap = Free: 2.25GB (98%), Used: 0.03GB (2%), Total: 2.29GB
Root = Free: 50.75GB (90%), Used: 5.10GB (10%), Total: 58.26GB
Updates = 0 apt updates available.
openHAB 3.3.0 - Release Build
openjdk 11.0.16 2022-07-19
OpenJDK Runtime Environment (build 11.0.16+8-post-Raspbian-1deb11u1)
OpenJDK Server VM (build 11.0.16+8-post-Raspbian-1deb11u1, mixed mode)
I try to use the LAN for Internet and want to use the WLAN for IOT devices like the shellys. As network coordiator i usa a old Fritz7141 as AP
I want to connect the Openhabian PI via WLAN to the IOT network but i cant.
openhabian@openhabian:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
# WiFi configuration generated by openHABian
country=DE
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
# Network configuration was created by wpa_passphrase to ensure correct handling of special characters
network={
ssid="HaAuSy"
#psk="[GELÖSCHT]"
psk=[GELÖSCHT]
key_mgmt=WPA-PSK
openhabian@openhabian:~ $ iwgetid
after reboot
openhabian@openhabian:~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"HaAuSy"
Mode:Managed Frequency:2.437 GHz Access Point: 00:04:0E:DB:02:EA
Bit Rate=5.5 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=70/70 Signal level=-33 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1 Invalid misc:0 Missed beacon:0
openhabian@openhabian:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.21 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::ff1f:6619:6022:2819 prefixlen 64 scopeid 0x20<link>
inet6 2002:95ac:fdc:0:8ea4:7302:87a9:d4a3 prefixlen 64 scopeid 0x0<global>
ether b8:27:eb:12:3b:00 txqueuelen 1000 (Ethernet)
RX packets 1310301 bytes 1944967515 (1.8 GiB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 641895 bytes 51667246 (49.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 59 bytes 6513 (6.3 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 59 bytes 6513 (6.3 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::4e7d:7c21:6d41:93bf prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:47:6e:55 txqueuelen 1000 (Ethernet)
RX packets 201 bytes 63636 (62.1 KiB)
TX packets 63 bytes 21721 (21.2 KiB)
Settings of the IOT Fritzbox
IP-Adresse: 192.168.176.1
Subnetzmaske: 255.255.255.0
DHCP-Server: aktiviert
von: 192.168.176.20
bis: 192.168.176.200
Is it possible that the LAN deaktvates the WLAN?
