WLED control without the binding
It looks like you should be able to with the HTTP API.
You could add the following Channel to the Thing (untested):
			Type number : preset "Preset" [
				commandTopic="wled/RGB2/api",
				formatBeforePublish="PL=%s",
				stateTopic="wled/RGB2/v",
				transformationPattern="XPATH:/vs/ps/text()"
Link that to a Number Item, and if using a Sitemap set the mappings appropriately.
I don’t use presets, so can’t test this.
Thanks, works like a charm !
You will also get PLAYLISTS mixed in with the PRESETS, the binding will sort them into different channels. The API treats both of those very similar.
