I have created a little tool to receive all information from the WOLF Smartset online portal into openhab.
It can be used as a alternative to a ebus coppling with the official WOLF gateway and the official Wolf Cloud-Portal.
Download
Usage
Replace <<USERNAME>>
and <<PASSWORD>>
with you Log-in credentials from https://www.wolf-smartset.com/ Portal.
The WolfSmarset Collecor will query the Smartset API for you Heating configuration and genreate all needed Item, Rules, script and sitemap files in the specified output-directory.
run dotnet .\WolfSmartsetCollector.dll -u "<<USERNAME>>" -p "<<PASSWORD>>"
Generated files
- items\wolf_smartset.items
- rules\wolf_smartset.rules
- Scripts\request_config.sh
- Scripts\request_token.sh
- Scripts\request_values.sh
- sitemaps\wolf_smartset.sitemap
Requirements
- Linux / Bash
- JsonTransform (http://docs.openhab.org/addons/transformations/jsonpath/readme.html)
- curl accessable via Path (I use http://www.paehl.com/open_source/?CURL_7.55.1)
- Recommend: Basic UI
- https://www.wolf-smartset.com/ Account and a ISM7i, ISM7e, Wolf Link Pro or Wolf Link Home
Tested WOLF-Devices
WOLF Equipment | openhab Version | Used gateway |
CSZ (CGB and SM1) | 2.5 | WOLF Link Pro |
Note: Please update this table if you did a successfull test
Supported Heating-Devices
Regarding documentation from WOLF
Heating system | WOLF Link home | WOLF Link pro |
Gas-Brennwertgerät CGB-2, CGW-2, CGS-2 | ![]() |
Öl-Brennwertgerät TOB | ![]() |
Gas Brennwertkessel MGK-2 | ![]() |
Split-Luft/Wasser-Wärmepumpe BWL-1S | ![]() |
Öl Brennwertgerät COB | ![]() |
Gas Brennwertkessel MGK | ![]() |
Gas Brennwertgeräte CGB, CGW, CGS, FGB | ![]() |
Gas Heizwertgeräte CGG-2, CGU-2 | ![]() |
Kesselregelungen R2, R3, R21 | ![]() |
Monoblock-Wärmepumpen BWW-1, BWL-1, BWS-1 | ![]() |
Mischermodul MM, MM-2 | ![]() |
Kaskadenmodul KM, KM-2 | ![]() |
Solarmodule SM1, SM1-2, SM-2, SM2-2 | ![]() |
Comfort-Wohnungs-LĂĽftung CWL Excellent | ![]() |
Klimageräte KG Top, CKL Pool* | ![]() |
Lüftungsgeräte CKL, CFL, CRL* | ![]() |
Blockheizkraftwerke | ![]() |
