I have installed the Wolf Smartset binding and I’m getting not all of the parameter I get if using the Wolf Portal e.g. “Warmwassertemperatur”. Other parameter e.g. “Heizgerät Eingang E1” shows a value of 65088 where I expect a 0 or a 1.
Binding, Things and Items installed straight forward with the paperUI.
Can you help with a hint what could be wrong in my setup or configuration?
because I have no documentation on WOLF codes I can’t check if the codes of CGB and TOB are the same. For me it looks they are not and therefore there is maybe a different relation.
At this time I have disabled all Things belonging to this Binding. Does it help to post the responses? Only one example: At the Input E1 I would expect 0 or 1, but 02000 or 65554 is shown (what I remember).
