Good evening everyone.
My openHAB 3.0.2 is running on a RPi4 and works great. I successively added most of my KNX stuff room by room and was able to connect openHAB to HomeKit. All items added so far are working with openHAB and showed up in HomeKit after tagging (switchable, lighting, windowcovering,…). Now I tried to add two more lighting items (working correctly with openHAB) to HomeKit but they do not show up. I tried different metadata tags, rebooting, cleaning cache, deleting thing (KNX actuator), items and channels multiple times but nothing worked.
I then added other items (linked to channels of the same thing (KNX switching actuator) of the two unwilling items) to HomeKit via metadata tags and they new ones showed up!
I double checked the KNX config ( GA, flags) but I cannot see a problem. The two lighting items work fine but just won’t pop up in HomeKit.
I did not try to unpair openHAB for I am not sure if this will fix it as my openHAB bridge is paired correctly and all other items work fine with HomeKit.
Is there someone with a hint or the same problem?
Markus
