Hi is there someone with a working pilight config ?
The command processing between plight and openhab is only sending commands when the state in plight is changing but i would like to use the
received command statement in the rule
any suggestions ?
Yes, I’m using pilight v.7 with openhab v1.7 (and mysensors v1.4). I use pilight to switch on the lights using Kaku (RF433). I have both rules in pilight and in openhab. It’s working fine. What is exact your problem?
