hermann1514
(Hermann Mueller)
November 6, 2018, 8:26am
#1
I set up my devices via PaperUI and everything works. Now I would like to create a few groups. There are several possibilities:
Create a group in PaperUI
Create a group in a config file
But how do I best relate the things to the group?
If I do this over PaperUI I have to select the group for each thing. I find that very confusing.
It would be nice if I could change the group in PaperUI.
How can I display all members of a group?
If I declare the thing again in an Configfile then I get the message that the device already exists.
What is the best way?
greeting
Hermann
vzorglub
(Vincent Regaud)
November 6, 2018, 9:17am
#2
You don’t put things in groups, you put items in groups
I don’t think you can do that yet
You need to remove the link in the paperUI and delete the item in the paperUI
The in the *.items file you do:
Group myGroup
ItemType ItemName "ItemLabel" (myGroup) { channel="channelnamefrompaperUI" }
To display all items in a group in a sitemap see: https://www.openhab.org/docs/configuration/sitemaps.html#element-type-group
hermann1514
(Hermann Mueller)
November 6, 2018, 9:38am
#3
Thank you.
The information about the group assignment I have already read.
So i should better make the configuration in the config files than in PaperUI - right?
vzorglub
(Vincent Regaud)
November 6, 2018, 10:06am
#4
It’s more flexible… For now…
I am an old time user, so I am used to the textual config.
Up to you but I recommend it
