Hey,
im just starting to implement my Homematic IP Setting into Openhab. I have some Heating Groups which are defined in Homematic (CCU3) and also imported into Openhab.
The Groups also have a LowBat-Switch-Channel - and i would like to know how it works ?
When one Items which is inside my Group gets a LowBat Warning will theLowBat Switch from the Group turn on ?
Im using Rules to send me a Telegram Message when an Items is on LowBat - so this would be nice to know and i have to watch for only one Switch instead of 4-5....just dont know how to test this…i haven`t any low Batteries here at the moment…maybe someone can contribute ?
rule "Notification when a battery is low"
Member of gBatteries changed to ON
var String msg = String::format("Sensor %s has a low battery", triggeringItem.name)
logWarn("battery low", msg)
I want to use this exactly as suggested above but I can’t get the transformation to work. In other words: I don’t want the output to be:
Sensor Sensor1_LowBattery has a low battery
but Sensor kitchen has a low battery
I’ve read the transformation chapter in the docs but as a beginner I still don’t know how to “combine” the line var String msg = String::format("Sensor %s has a low battery", triggeringItem.name)
with something like transform("MAP", "battery.map", %s)
I already added all of my battery driven devices to the battery.map file which looks like this:
