I’m a running a simple web server
Works great but I am having difficulties read in the data into openhab
The web output looks like this
[{“relay_port”: 4, “x_port”: 0}]
I need 2 x items displaying 1 integer each. The help file say that the output is a json file.
I just want the Intergers displayed.
Sounds terrible but I need help if anyone can spare the time.
Kind regards
Jason
david
(david)
2
You will need to use a transform, and then you can assign them to an item.
create the transform/relay_port.js file with the below content.
JSON.parse(input).relay_port;
Then reference it in your items file.
Number RelayPort "" { http="<[http://xxx.xxx.xxx.xxx:80/url:60000:JS(relay_port.js)]" }
Then repeat for the second value. Each transform is in it’s own file.
Thank you so much for taking the time to respond. I have followed your post, but I am only reading a “-” when displaying the item.
Just to recap
- created the json file in /opt/openhab/configurations/transform.
- relay_port.js with line 1 line only
- created item
Number RelayPort "" { http="<[http://10.0.1.84:8000/:60000:JS(relay_port.js)]" }
- sitemap entry
Text item=RelayPort label="Relay Port [%d]"
BTW the web server in am using is
https://github.com/piface/pifacerelayplus/blob/master/docs/simplewebcontrol.rst
It is awesome!
Kind Regards
Jason
Hi Jason,
hope you waited some time for getting the item updated? the 6000 is the refreshrate in miliseconds.
Start - before getting the item into a Number putting this one into a string item istead to see what the transform gets back at all.
String RelayPort “RelayPort [%s]” { http="<[http://10.0.1.84:8000/:60000:JS(relay_port.js)]" }
In addition it seems that the item type definition is missing in your number item:
Number RelayPort “RelayPort [%d]” { http="<[http://10.0.1.84:8000/:60000:JS(relay_port.js)]" }
cheers
Karsten
Hi Karsten,
Thank you, it did update the type definition as suggested. I also updated the time to 2000 ms. Also change the item names.
The int is displaying “-”
and the String is displaying a “null”
Screen shot of log.
I did manage to get it working with a REGEX, but it seems that it is not the best practice.
Once again, thanks for all the help.
Kind Regards
Jason
david
(david)
6
I’m no json expert, but I am wondering if it is the square brackets causing the parser to not find the path.
Can you have the webserver return {“relay_port”: 4, “x_port”: 0} instead?
Hi, sorry for the late response. It does seem to be an issue with the [ ]'s
I will have a look and see if I can modify the code to exclude the [ ]'s.
Once again, thank you so much for the assistance and patients.
Kind Regards
Jason
Have you tried jsonpath instead?
