Does this mean the following would not work anymore?
if (Weather_MaxTemp_0.state > 23) {
Is it mandatory to use
Number:Termperature instead of Number items?
No it should still work. It does for me.
Is there any way to do math in line of an if statement ?
ex:
if ( atticTemperature.state < (atticSetpoint.state as QuantityType<Temperature> + "0.5 °F" ) )
Iāve tried a dozen different variations and they all fail with something along :
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'attic test something something': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.lib.NumberExtensions.operator_lessThan(org.eclipse.smarthome.core.types.Type,java.lang.Number) on instance: null
the closest I got with no errors (but didnāt seem to work anyway was:
rule "attic test something something"
Item atticSetpoint changed
if ( atticTemperature.state > (atticSetpoint.state as QuantityType<Temperature> + 0.5 ) )
logInfo("success","addition")
but i never got the success logging. i also donāt get any other errorsā¦soā¦progress? hah!
if ( atticTemperature.state > ((atticSetpoint.state as Number) + 0.5 ) )
hey all,
how can i make this rule work with this?
items
Number:Temperature Weather_Temperature "Temperatuur buiten [%.1f %unit%]" <temperature> (gTemperatures, gWeather) { channel="openweathermap:weather:api:local:current#temperature" }
Number Weather_Temp_Min "Temp. buiten Min [%.1f °C]" <temperature> (gWeather)
Number Weather_Temp_Max "Temp. buiten Max [%.1f °C]" <temperature> (gWeather)
rules
rule "Set daily max and min temperature"
Item Weather_Temperature changed or
Time cron "0 0 0 * * ?" or
System started
val max = Weather_Temperature.maximumSince(now.withTimeAtStartOfDay)
val min = Weather_Temperature.minimumSince(now.withTimeAtStartOfDay)
logInfo("rules.weather", "Temperatuur is " + Weather_Temperature.state)
if( max !== null && min !== null) {
postUpdate(Weather_Temp_Max, max.state)
postUpdate(Weather_Temp_Min, min.state)
logInfo("rules.weather", "Max Temperatuur is " + max.state)
logInfo("rules.weather", "Min Temperatuur is " + min.state)
What not working right now?
it wasnāt updating Weather_Temp_Max and Weather_Temp_Min, but i changed it to this, and that works so far now.
System started
var Number CurrentValue = (Weather_Temperature.state as QuantityType<Number>).doubleValue
postUpdate(Weather_Temp, CurrentValue)
val max = Weather_Temp.maximumSince(now.withTimeAtStartOfDay)
val min = Weather_Temp.minimumSince(now.withTimeAtStartOfDay)
logInfo("rules.weather", "Temperatuur is " + CurrentValue)
You need to include one missing definition. At the top of your rules file, add:
import org.eclipse.smarthome.core.library.unit.SIUnits
I believe this missing include will be automatically added at a certain point in time.
Thank you @Lolodomo!
Just used your syntax for the DarkSky binding to remove the UNIT value so I could use it else where.
rule "Remove UNITS from Temperature and Round Numbers for Alexa"
Item FIOTemp received update or
Item FIOTemp_Min0 received update or
Item FIOTemp_Max0 received update or
Item FIOTemp_Min1 received update or
Item FIOTemp_Max1 received update or
Item FIOTemp_Min2 received update or
Item FIOTemp_Max2 received update or
Item FIOTemp_Min3 received update or
Item FIOTemp_Max3 received update or
Item FIOTemp_Min4 received update or
Item FIOTemp_Max4 received update
if (systemStarted.state != ON && FIOTemp.state != NULL && FIOTemp.state !== null && FIOTemp.state != UNDEF) {
FIOTemp_Number.postUpdate((FIOTemp.state as QuantityType<Number>).doubleValue)
logInfo("FIO" , "FIOTemp_Number postUpdate is at " + FIOTemp_Number.state)
// Used for Alexa Speaking
val roundedNumber1 = (Math::round((FIOTemp_Number.state as DecimalType).floatValue()* 10)).floatValue() / 10
FIOTemp_Rounded.postUpdate(roundedNumber1)
Hi All, I am following this thread with interest and have tried various things from the replies, but I can get this to work:
var o_trigger = HueOutdoorTemperatureSensorTemperature.state + 2 | °C
It results int he following error in the log:
2020-01-06 20:41:45.598 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Shed Fan ON': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
The value of HueOutdoorTemperatureSensorTemperature.state is 7.61 °C
Could you give some pointers please?
So after spending about 3 hours doing thsi and posting thes question, I finally sussed it:
val o_trigger = (HueOutdoorTemperatureSensorTemperature.state as QuantityType<Temperature>) + 2 | °C
