Hey guys,
I have added two window/door contacts (aqara window/ door contact) to all of my windows. One of them at the top and one at the bottom of the window. The reason is, I want to know if a window is open/ closed or tilted.
The item type contact only supports the states OPEN and CLOSED, so I created the following items for every window:
// Fenster Büro rechts
String FensterBueroRechts "Fenster Büro (rechts)"
Contact FensterBueroRechts_oben {channel="deconz:openclosesensor:00212E054B9D:00158d0004a02799010006:open"}
Number FensterBueroRechts_oben_battery_level {channel="deconz:openclosesensor:00212E054B9D:00158d0004a02799010006:battery_level"}
Contact FensterBueroRechts_unten {channel="deconz:openclosesensor:00212E054B9D:00158d0002d442b2010006:open"}
Number FensterBueroRechts_unten_battery_level {channel="deconz:openclosesensor:00212E054B9D:00158d0002d442b2010006:battery_level"}
My rule looks like this:
var rulename = "fensterkontakte.rules"
rule "Fensterkontakt Büro (rechts)"
Item FensterBueroRechts_unten changed or
Item FensterBueroRechts_oben changed
logInfo(rulename, "Fensterkontakt Büro (rechts) ausgelöst")
logInfo(rulename, "Fensterkonakt oben: "+ FensterBueroRechts_oben.state)
logInfo(rulename, "Fensterkontakt unten: "+ FensterBueroRechts_unten.state)
if (FensterBueroRechts_oben.state == CLOSED && FensterBueroRechts_unten.state == CLOSED) {
logInfo(rulename, "Fensterkontakte oben und unten geschlossen.")
logInfo(rulename, "Aktueller Stand: "+ FensterBueroRechts.state)
FensterBueroRechts.sendCommand("Geschlossen")
return ;
if (FensterBueroRechts_oben.state == OPEN && FensterBueroRechts_unten.state == CLOSED) {
logInfo(rulename, "Fensterkontakte oben geöffnet.")
FensterBueroRechts.sendCommand("Gekippt")
return ;
if (FensterBueroRechts_oben.state == OPEN && FensterBueroRechts_unten.state == OPEN) {
logInfo(rulename, "Fensterkontakte oben und unten geöffnet.")
FensterBueroRechts.sendCommand("Geöffnet")
return ;
This is working fine, but maybe there is a better opportunity to realize this?
Thank you
