Worx Landroid Binding
Many thanks for this! Working for me too.
Thank you so much! I had the same issue since a couple of days and now it works again :slight_smile:
Is there a reason why this binding cannot be installed like all the other bindings via the UI?
It’s in the review process:
The bridge thing is online, but i dont get any updates to the items. I have to disable and reenable the bridge thing and it works again. The logs show no errors. I use this Worx Landroid Binding - #604 by Kampfiltis version.
Anybody else facing this issue?
Updated to version 4.3 : marketplace/org.openhab.binding.worxlandroid-4.3.0-SNAPSHOT.jar at 4da4afdb11d1d73e3ac8eac620334767d8e015d6 · clinique/marketplace · GitHub
Thanks! I’ll try that version
Unfortunately, the problem still exists.
Tested with openHAB 4.2 Release, works without any problems, thx.
Restarting openhab solved it
I tryed to install the binding at Openhab 4.1.2 Release Build. But I get an error:
Can't load features repository mvn:org.openhab.core.features.karaf/org.openhab.core.features.karaf.openhab-core/4.0.4-SNAPSHOT/xml/features
What I did, was to copy
into /usr/share/openhab/addons and restarted openhab.
What else do I have to do? Or what is wrong?
Hi
After a few days of work, I managed to make the binding compatible with the Vision models
you can find the binding at this link
for the source code I started from
the most change of source are about the Multi Zone.
i don’t have multi zone in my garden so i don’t know if it work with vision models, i wish to not broke the currently multizone
someone can test it, and in case give me a feedback
thanks
PS
I would like to share my changes without having to create another repository but keeping a single point for our beloved landroid
Thanks @Bramante,
Have dropped it in. It has found my vision m straight away. Unable to test till tomorrow. Will let you know how it goes over the next few days.
I think it is a bad idea to maintain two binding versions.
Is there any specific reason why you did not provide the changes to the PR for the official binding?
I want put to the official binding, but before do it, i preferer to verify that my work is fine and that my fix doesn’t broke anything, because of this I ask if someone can test my binding with the vision models (in my case work fine) and the normal models
the fix I do, change how the binding interact with the JSON from server API call and the multizone.
if all will be OK I am very happy to release the fix in the official repository
I have updated to the version 4.3 and now I have the problem that the next start time and the next stop time are wrong. It shows the time of slot 2 and not slot 1.
I have restarted openhab and cleared the cache, but to no success.
Any idea?
Sorry, could not read all posts. But is this binding able to communicate with the rower “offline” (I mean no Internet)?
Why is it still not in official repro?
No.
Review of PR is not yet finished, see above.
Have you solved the problem? I have the same problem.
After some time the status of the mower isn’t updated any more although the bridge and mower thing and the common#online channel status is online. Only disabling an enabling of the bridge and mower thing helps, but after some time the problem occours again.
PS: the aws#connected channel status is also online even if the connection is lost
What is the right .jar for OH4.2.1?
Or shall I rather wait until it is in the official repo, review seems to be almost finished.
