yes, the error message “wrong email or password” refers to the settings from the “landroid-s” section. Please make sure you’ve entered the correct credentials for your Landroid Cloud account here (the one you’re using in the mobile Landroid app) .
There also seems to be something wrong in your MQTT connection URL. Username and password are usually separated like this: mqtt://username:password@localhost
Sorry,
but i think i need your help again. Since yesterday he tries initialize the bridge. But he said, “mower not found, fallback to first mower”.
homeautomation@Skynet:~/Downloads/landroid-bridge$ node dist/server.js
[2018-07-29T09:38:04.669] [INFO] server.ts - Starting Landroid Bridge…
[2018-07-29T09:38:04.674] [INFO] server.ts - Setting port to 3000…
[2018-07-29T09:38:04.766] [INFO] Mqtt - Connecting to MQTT Broker…
[2018-07-29T09:38:04.818] [INFO] App - Adding static files path /home/homeautomation/Downloads/landroid-bridge/www
[2018-07-29T09:38:04.820] [INFO] Scheduler - Skipping scheduler initialization (not enabled)
[2018-07-29T09:38:04.834] [INFO] LandroidS - Initializing Landroid Cloud Service…
[2018-07-29T09:38:04.927] [INFO] Mqtt - Successfully connected to MQTT Broker!
[2018-07-29T09:38:05.251] [INFO] IoBrokerAdapter - Logged in as xxx@xxx.xx API Token Set to : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2018-07-29T09:38:05.709] [INFO] IoBrokerAdapter - mower not found, fallback to first mower
[2018-07-29T09:39:04.836] [INFO] LandroidS - Could not finish initialization, retrying…
[2018-07-29T09:39:05.223] [INFO] IoBrokerAdapter - Logged in as xxx@xxx.xx API Token Set to : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2018-07-29T09:39:05.614] [INFO] IoBrokerAdapter - mower not found, fallback to first mower
[2018-07-29T09:40:04.840] [INFO] LandroidS - Could not finish initialization, retrying…
[2018-07-29T09:40:05.217] [INFO] IoBrokerAdapter - Logged in as xxx@xxx.xx API Token Set to : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2018-07-29T09:40:05.719] [INFO] IoBrokerAdapter - mower not found, fallback to first mower
[2018-07-29T09:41:04.842] [INFO] LandroidS - Could not finish initialization, retrying…
[2018-07-29T09:41:05.268] [INFO] IoBrokerAdapter - Logged in as xxx@xxx.xx API Token Set to : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2018-07-29T09:41:05.748] [INFO] IoBrokerAdapter - mower not found, fallback to first mower
[2018-07-29T09:42:04.844] [INFO] LandroidS - Could not finish initialization, retrying…
[2018-07-29T09:42:05.275] [INFO] IoBrokerAdapter - Logged in as xxx@xxx.xx API Token Set to : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[2018-07-29T09:42:05.727] [INFO] IoBrokerAdapter - mower not found, fallback to first mower
@Hooch@curro:
I’ve committed a new version to GitHub and Docker Hub yesterday. Could you please give the new version a try and see if the error still occurs?
Thanks!
I use the bridge to bring the Landroid Worx S into smartVISU. The status information and the landroid/set/start and landroid/set/stop work fine. But on the landroid/set/mow command I got an error message.
Hi, I also don’t understand how to get a working ON/OFF Button in OH to work with MQTT2-Binding.
With these settings I have no success:
Anyone has this working?
1: Edit package.json to change the referenced version of ioBroker.landroid-s from 2.5.4 to 2.5.5
2: Edit the src/LandroidS.ts file changing import * as LandroidCloud from "iobroker.landroid-s/lib/landroid-cloud-2"; to import * as LandroidCloud from "iobroker.landroid-s/lib/mqttCloud"; as noted in the pull request.
3: Execute npm run grunt to rebuild and pull the new stuff.
