- Platform information:
- Hardware: Compulab IoT hw with RPi3B Compute module
- OS: debian 10.11
- Java Runtime Environment: OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
- openHAB version:3.2.0
- Issue of the topic:
The installation works fine, but the error shown in dmesg repeated several times per 100 ms is worrying, see below.: - Please post configurations (if applicable):
- Some 10 items are read and stored in InfluxDB every minute
- If logs where generated please post these here using code fences:
output from dmesg:
[533351.302744] Write-error on swap-device (254:0:886112)
[533351.308261] Write-error on swap-device (254:0:985960)
[533351.313796] Write-error on swap-device (254:0:637328)
output from df:
[22:24:10] openhabian@<myIP>:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 14657232 6575580 7444460 47% /
devtmpfs 464772 0 464772 0% /dev
tmpfs 498052 0 498052 0% /dev/shm
tmpfs 498052 1460 496592 1% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 498052 0 498052 0% /sys/fs/cgroup
/dev/mmcblk0p1 258095 49305 208791 20% /boot
/dev/zram1 588352 924 544420 1% /opt/zram/zram1
overlay1 588352 924 544420 1% /var/lib/openhab/persistence
/dev/zram2 689128 173812 465140 28% /opt/zram/zram2
overlay2 689128 173812 465140 28% /var/log
tmpfs 99608 0 99608 0% /run/user/1000
and from free -ht:
[22:25:15] openhabian@<myIP>:~$ free -ht
total used free shared buff/cache available
Mem: 972Mi 769Mi 31Mi 0.0Ki 170Mi 192Mi
Swap: 2.6Gi 1.9Gi 656Mi
Total: 3.5Gi 2.7Gi 688Mi
