Indeed writing 32 bit floats is not supported by the binding – the values are converted to 16bit int and then written to single register. This is known limitation which is also mentioned on the wiki pages
That’s what I thought. But I did not quite understand your last position on that. Not very clear to me. Moreover, I thought maybe this limitation has been corrected.
Think you make this correction?
In this case, is it possible to set up read and write 16-bit and 32-bit BCD?
