Thanks Rich for your help.
Currently I can select my spotify playlists from a selection item:
Selection item=Volumio1_Spotify_TrackToPlay label="Playlist Spotify" icon="spotify" mappings=[
"spotify:user:spotify:playlist:37i9dQZF1DX2JKi7oFC6Jv" = "UK Funky House",
"spotify:user:spotify:playlist:37i9dQZF1DWUraJYejk11q" = "Genre Glitch",
"spotify:user:spotify:playlist:37i9dQZF1DX6VdMW310YC7" = "Chill Tracks",
"spotify:user:spotify:playlist:37i9dQZF1DX1tyCD9QhIWF" = "Walk Like A Badass",
"spotify:user:spotify:playlist:37i9dQZF1DX82pCGH5USnM" = "Lounge - Soft House"
This works pretty well.
Now I’m trying to achieve a dynamic update of this part in my .sitemap file.
What I’ve done so far:
Code for loading the playlist from the Spotify API:
// Imports
import java.nio.file.Path
import java.nio.file.Paths
import java.nio.file.Files
import java.nio.file.StandardOpenOption
import java.util.List
import java.util.Collections
import java.util.Arrays
// Rule
logInfo("Spotify", "Updating Playlists")
var String token = spotifyAPIaccessToken.state.toString
var String api = "https://api.spotify.com/v1/users/%%USERNAME%%/playlists"
var int limit = 10
var int offset = 0
var String command = 'curl@@-s@@-w@@%{http_code}@@-X@@GET@@' + api + '?limit='+ limit.toString +'&offset=' + offset + '@@-H@@Content-Type:application/json@@-H@@Accept:application/json@@-H@@Authorization: Bearer ' + token + "@@"
var String result = executeCommandLine(command, 5000)
var int results_total = Integer::parseInt(transform("JSONPATH", "$.total", result))
logInfo("Spotify", results_total.toString + ' Playlists found.')
while (offset <= results_total) {
logInfo("Spotify", offset.toString)
result_uri = transform("JSONPATH", "$.items[*].uri", result)
result_name = transform("JSONPATH", "$.items[*].name", result)
offset=offset+limit
logInfo("Spotify", result_uri.toString)
I get the following Output as an example for the URI:
2020-04-13 18:23:22.936 [INFO ] [lipse.smarthome.model.script.Spotify] - ["spotify:playlist:0o6avg8A392phKcm6R5oMK", "spotify:playlist:37i9dQZF1DWTyiBJ6yEqeu", "spotify:playlist:37i9dQZF1DWYUYYlhkTuEn", "spotify:playlist:5VUb9j8U58G36KL4ojb6rn", "spotify:playlist:0EC1TFMmN26VbVvXao8iMc"]
I’m struggling to put the uri and the name back together in the shown format from my sitemap and to write it into my existing sitemap file.
I think it’s a very complicated way to do this, but i’ve no idea if there are any alternative ways to do this …
What I’ve tried so far:
(It’s not yet ready)
val Path path = Paths.get("/openhab/conf/sitemaps/home_copy.sitemap")
logInfo("execTest", Files.isWritable(path).toString)
var List<String> content = Files.readAllLines(path)
logInfo("execTest", content.indexOf("// <---").toString)
logInfo("execTest", content.indexOf("// --->").toString)
// Removal
for (var int i = 0; i <= (content.indexOf("// --->")-content.indexOf("// <---")) ; i++) {
//content.remove(i)
logInfo("execTest", i.toString + " : " + content.get(content.indexOf("// <---")+i))
// Add
for (var int i = 0; i <= uri.size; i++) {
//logInfo("execTest", i.toString + " : " + uri.get(i))
//Collections.replaceAll(content,"foo", "bar")
Files.write(path, content, StandardOpenOption.CREATE, StandardOpenOption.TRUNCATE_EXISTING, StandardOpenOption.WRITE)
