It took me also a bit before I more or less understood how it works. I’ve setup mine using PaperUI, so I can’t show you my Thing file because I don’t have one.
A couple of things (no pun intended) first. In your Thing file, you have channels defined for the sunset (set#event
) and sunrise (rise#event
) events. However, in your items file you have defined two items, one for daylight start (daylight#start
) and daylight end (daylight#end
). You did not define an offset for daylight, so that is the reason why the items do not have an offset.
If you want to use daylight
then you need to use two Things because you want to use two different offsets for the same group.
Type rangeEvent : daylight#event [
offset=-30
offset=30
In the above example there is no way openHAB can know which one to use when, so this will not work. Hence the need for two different Things, one for each daylight offset:
The myastrothing1.thing
file for daylight start:
astro:sun:myastrothing1 [ geolocation="my coords, my cords", interval=60 ] {
Channels:
Type start : daylight#start [
offset=30
offset=30
The myastrothing2.thing
file for daylight end:
astro:sun:myastrothing2 [ geolocation="my coords, my cords", interval=60 ] {
Channels:
Type start : daylight#end [
offset=-30
offset=-30
and the corresponding items file:
DateTime Day_Start "Day Start [%1$tH:%1$tM]" { channel="astro:sun:myastrothing1:daylight#start" }
DateTime Day_End "Day End [%1$tH:%1$tM]" { channel="astro:sun:myastrothing2:daylight#end" }
rule "Test Daylight"
System started or
Time cron "0 1 0 * * ? *"
val day_start = new DateTime(Day_Start.state.toString).plusMinutes(-10)
val day_end = new DateTime(Day_End.state.toString).plusMinutes(10)
var drive_curr = "DARK"
if (now.isAfter(day_start) && now.isBefore(day_end) ){
drive_curr = "LIGHT"
DriveState.sendCommand(drive_curr)
I don’t think the above rule will do what you originally intended. You could try to trigger a rule when either Day_Start
or Day_End
is changed. That should happen when the Astro binding has done its calculation (at least that works in openHAB 1.x). Just make sure that neither of them is null or undefined when doing calculations with them.
rule "Test Daylight start"
Channel 'astro:sun:myastrothing1:daylight#event' triggered START
DriveState.sendCommand("LIGHT")
rule "Test Daylight end"
Channel 'astro:sun:myastrothing2:daylight#event' triggered END
DriveState.sendCommand("DARK")
If you want to use sunrise and sunset instead (which I now know you don’t but I’ll leave it for reference), then the following may work:
astro:sun:myastrothing [ geolocation="my coords, my cords", interval=60 ] {
Channels:
Type start : rise#start [
offset=30
Type start : set#start [
offset=-30
Type rangeEvent : rise#event [
offset=30
Type rangeEvent : set#event [
offset=-30
DateTime Day_Start "Day Start [%1$tH:%1$tM]" { channel="astro:sun:myastrothing:rise#start" }
DateTime Day_End "Day End [%1$tH:%1$tM]" { channel="astro:sun:myastrothing:set#start" }
In PaperUI I cannot link an item to the rangeEvent
channel, hence in my system I have my item connected to the Start Time
channel. I have both the Start Time
channel and the rangeEvent
channel configured with the same offset. That way the linked item shows the correct time when the rangeEvent
is triggered to close my rollershutters.
Unfortunately, the documentation does not show any complex examples, so if the above works then please let me know.
