Ok, i will have a look at that.
I am using txt files for Things, Channels and items. So i have to create a trigger channel and see how it reflects in the UI to a txt created channel.
A good example of the benefits of managing things and items through MainUI. I made the transition and I never regret it. Just to encourage you…
Ok, configured an event channel and got the loginfo written.
Channel "mqtt:topic:MyMQTTBroker:IkeaSwitchrund1:EventChannel" triggered brightness_up_click
logInfo('MIRHOME', 'Rule triggered ' + receivedEvent)
With nothing behind “…” triggered it does not work.
I would like to do the identifying what message was triggered in an IF Statement like this:
var actionName = receivedEvent
if(actionName == "toggle") {
gLights.sendCommand(OFF)
if(actionName == "brightness_down_click") {
gLightsdimmer.sendCommand(50)
Is this possible?
yes, it is possible.
If you use
What does loginfo say?
Ok, it triggered and had the text… Easy as hell ![]()
Well i wont spend time why it didnt do right after i created the Event Channel. maybe i didnt save the rule.
Now ill try to go up in steps if “brightness_up_click” is triggered. That means you will hear from me again ![]()
Thnx a lot for your time, all of you.
Cheers
Michael
