Hi all,
I want to write the outside temperature to my KNX bus to display it iin several glass switches from MDT, BE-GT2TS.01.
What I did so far is defining an item for the temperature. That works fine and shows me correct values when I add this item to a sitemap.
Further, I know the address where I have to send the temperature to, that is 0/2/0.
Now, I have troubles to join both. I tried:
control.things
Bridge knx:ip:bridgeControl [
type="TUNNEL",
ipAddress="192.168.178.36"
Thing device temperatureWriter "Aussentemperatur" @ "KNX" {
Type number : Temperature "Aussentemperatur" [ ga="0/2/0" ]
and knx.items:
Number Temperatur_Aussen "Aussentemperatur [%.1f °C]" <temperature> (Aussen) { channel="knx:device:bridge:generic:Temperatur_Arbeitszimmer_IST", channel="knx:device:bridgeControl:temperatureWriter:Temperatur_Aussen" }
But that does not work yet. Sorry, I’m quite a beginner, does someone has a hint for me how to get it working?
Thanks in advance,
Carsten
