because I got some problems with one Z-Wave device i’ve reseted it to factory defaults and add it as a new Thing to OpenHab. The “old” device got Node ID 6, the New Node ID 8.
But obviously, the Thing wasn’t completely deleted.
I’m receiving the following errors:
2016-10-02 15:25:09.967 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '100' for item 'Battery_Multisensor_GF_Bath' to handler for channel 'zwave:device:d90ead21:node6:battery-level', because no thing with the UID 'zwave:device:d90ead21:node6' could be found.
(I’ve created the Item Battery_Multisensor_GF_Bath for Node ID 8 using an Item Definition.
I’ve tried to delete the old Item manually using habmin, but the backend receives this message:
2016-10-02 15:28:05.057 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP DELETE request at 'items/Battery_Multisensor_GF_Bath' for the unknown item 'Battery_Multisensor_GF_Bath'.
Node 6 and Node 8 are the same devices. PaperUI shows me Node 6 in the Inbox and Node 8 in “Configuration > Things”.
As I’ve just found out, Updates to Node 8 are not properly delegated to linked items. Maybe I have to remove Node 8 and include Node 6?
I use the UI for adding devices and the config files for linking them. Maybe I’ve created the item linked to Node 6 using the UI .
Yes, but only one can be active - the same device can’t have two node numbers. From the log it looks like node 6 is sending data, which means node 8 should be deleted?
Node 8? The error above is for node 6, or have you changed something since the original post?
Yes - I would delete node 8, do a discovery (don’t touch the device, just click the discovery button and devices should be added back in to the inbox).
Maybe - I know that when devices are deleted, the links can remain -:
It’s unclear to me which of these is alive so first we need to be sure… I suggest the following -:
Delete both node6.xml and node 8.xml
Restart the binding, clear the inbox, and do a discovery again
Both devices will likely be back in the inbox, but hopefully only one will have a meaningful name
Add the device that DOES NOT have a proper name (it should say Unknown or something)
This will create a thing for the device and we can then try and get rid of it from the controller
Select the thing, select the tools menu in HABmin, and select Advanced mode
You should then have an option to “Set device as FAILed” - select this
You should also have an option to “Remove device from controller” - select this
If the magic works, the device should be gone and if you remove the thing, and do another discovery, it hopefully won’t come back! Unfortunately I’m not 100% confident since removing devices like this requires that the controller itself thinks the device is FAILed and for battery devices especially, it can be hard to convince the controller that this is the case.
You can reset the controller completely using the “Hard Reset” option. Select the controller in the thing list, select advanced mode in the tools menu, and you should see an option “Hard Reset Controller”.
