I get this Warnign:
16:43:44.180 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘24.00’ for item ‘alexa_temp_set’ to handler for channel ‘homematic:HM-TC-IT-WM-W-EU:AAAAAA:MEQ0742406:2#SET_TEMPERATURE’, because no thing with the UID ‘homemati4c:HM-TC-IT-WM-W-EU:AAAAAA:MEQ0742406’ could be found.
the AAAAAA was an old ID, how can i remove it? the .items file is updated with the new ID…
so… there is somewhere in your system stored a flat config file that brings back these links… (OH2 re-reads it and re-creates the links even after the nuke option)
that usually happens with an old *.items file that is forgotten somewhere…
no, you can’t delete stuff from the control page
only from the configuration menu of PaperUI (but I assume that the old things do not appear there anymore…)
try also to: stop OH2 service, remove /var/lib/openhab2/tmp and /var/lib/openhab2/cache and start it up again.
The actual dir paths may be different on Synology package… not sure
Also, check for the jsonDB folder and look for old configs in there.
but it can not be deleted because i don’t have the permissions…
it took a while to google how i can delte things as root via command, but finally everthing in this folder is deleted and my bugs are gone thank you very much!!
