i’ve successfully added the “Xiaomi Mi Temperature & Humidity Sensor” but in HABPanel I see “20 ?C” not “20 °C” Did anyone have a idea to fix it?
Changing the Unit manually doesn’t work.
Best regards
Chris
Best regards
Chris
How do you have the item configured? You may also want to use the HABPanel tag for the topic.
I have configured it via PaperUI-Bindings and the Xiaomi Gateway. Everything works fine but only HABPanel doesn’t show the correct “°”.
It’s only HABPanel wich has this problem. The Value in Paper UI is shown in correct format.
Is it possible that the problem is based by the language server? I got multiple errors in log “adress already in use”. Get a few topics open and think the problems are all based in my difficulties after updated to openHAB 2.5.5 - i hope i will find a solution and let you know.
Now i’ve got the same mistake with “K?hlschrank” in PaperUI. Is it because of the errors caused by loading the language server? How can i fix it. I have no other ideas.
There were a lot more problems so i’ve deleted absolutely all and started completely new. A new installation of ubuntu and a proper installation of OpenHAB an all the bindings. Now everything works fine.
But you can reconfigure the shown value in HABPanel if you add this to “Format”: %.0f °C
That works nice!
