No that is not the point. E.g.
Number:Speed WeatherInformationForecastTomorrowMaxWindSpeed "Maximum wind speed [%.0f %unit%]" {channel="meteoblue:weather:62281c1e:forecastTomorrow#maxWindSpeed"}
is delivering a value of 7.7 km/h, however it should be 7.7 m/s or 27.72 km/h
See as well what I get from the meteoblue API:
"units":
"time": "YYYY-MM-DD hh:mm",
"predictability": "percent",
"precipitation_probability": "percent",
"pressure": "hPa",
"relativehumidity": "percent",
"co": "ug/m3",
"temperature": "C",
"winddirection": "degree",
"precipitation": "mm",
"windspeed": "ms-1"
"data_day":
"time": ["2020-02-26", "2020-02-27", "2020-02-28", "2020-02-29", "2020-03-01", "2020-03-02", "2020-03-03", "2020-03-04"],
"pictocode": [16, 2, 2, 3, 12, 12, 8, 3],
"uvindex": [1, 2, 2, 3, 1, 2, 1, 2],
"temperature_max": [6.23, 7.59, 6.24, 9.31, 7.42, 10.26, 9.16, 10.66],
"temperature_min": [1.49, 1.29, 1.68, 0.52, 4.96, 3.25, 5.64, 3.61],
"temperature_mean": [3.79, 4.44, 4.39, 4.86, 6.36, 6.59, 7.14, 7.05],
"felttemperature_max": [4.80, 3.46, 1.63, 6.37, 6.03, 8.37, 7.00, 8.10],
"felttemperature_min": [-3.13, -3.92, -2.36, -2.62, 2.42, 1.04, 2.81, 1.61],
"winddirection": [315, 315, 315, 225, 225, 180, 0, 315],
"precipitation_probability": [99, 9, 8, 5, 81, 28, 72, 25],
"rainspot": ["3333333333333333333333332333333333333333333333333", "0000000000000000000000000000000000000000000000000", "0000000000000000000000000000000000000000000000000", "0000000000000000000000000000000000000000000000000", "3333333333333333333333333333333333333333333333333", "2210000220000021211000011000000000000220000111000", "3333333333333333333333333333333333333333333333333", "0000000000000000000000000000000000010000001100000"],
"predictability_class": [4, 4, 4, 4, 2, 3, 2, 3],
"predictability": [71, 78, 80, 74, 37, 46, 27, 41],
"precipitation": [4.78, 0.00, 0.00, 0.00, 6.48, 1.38, 8.47, 0.00],
"snowfraction": [0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.00],
"sealevelpressure_max": [1003, 1010, 1023, 1022, 1011, 1013, 1011, 1011],
"sealevelpressure_min": [997, 1000, 996, 1008, 1006, 1007, 1007, 1000],
"sealevelpressure_mean": [1000, 1006, 1012, 1014, 1008, 1010, 1008, 1004],
"windspeed_max": [3.99, 4.55, 7.70, 2.47, 3.30, 3.53, 3.81, 2.85],
"windspeed_mean": [1.89, 3.16, 4.40, 1.47, 1.94, 1.76, 2.42, 1.55],
"windspeed_min": [0.18, 1.05, 0.23, 0.00, 0.62, 0.54, 1.23, 0.08],
"relativehumidity_max": [100, 93, 96, 100, 100, 100, 100, 100],
"relativehumidity_min": [81, 55, 56, 71, 94, 95, 97, 69],
"relativehumidity_mean": [98, 74, 75, 86, 100, 99, 100, 88],
"convective_precipitation": [0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 2.84, 0.00],
"precipitation_hours": [6.00, 0.00, 0.00, 0.00, 4.00, 1.00, 6.00, 0.00],
"humiditygreater90_hours": [20.00, 3.00, 2.00, 12.00, 24.00, 24.00, 24.00, 11.00]
