Xaomi aqara temperature humidity sensor
@taztura, @claudissimus
As @jswim788 already pointed out, you may use https://github.com/Koenkk/zigbee2mqtt. It’s pretty well documented regarding supported devices, required hardware, etc.
If you need help with the openHAB configuration, have a look here: Howto use zigbee2mqtt with openHAB, removing proprietary bridges / gateways.
