Issue of the topic: Cannot establish communication between two Xbee Zigbee modules
I have setup a Raspberry PI 4 with Openhabian, and connected a Xbee Zigbee board on it through USB port (=coordinator). I use the Zigbee Binding.
The coordinator is correclty recognized by Openhab. That’s the first good point!
I have an other Xbee module (also zigbee) which is in the same zigbee network than the coordinator. This 2nd module is sending a measurement (from an ADC input) through API mode to the coordinator. I can see that the transmission is OK thanks to the RSSI led on the Xbee boards (both led of coordinator and sender are blinking).
On the Openhab side, the 2nd Xbee board was triggered in the Inbox. I created one “Thing” from this Inbox notification, and then I am stuck.
The 2nd Xbee device (sender) is correclty listed in the “Things” list, with the correct MAC address. Nevertheless, its state is “Offline, Node has not completed discovery”.
I suppose that I have something to configure in order to define what type of data should be received from this Xbee module in order to allow Openhab to “understand” the message, or something like that, but I don’t know how and where to do that configuration.
I’m not sure I can directly help as I have no knowledge of producing an end device with the Xbee. I can however maybe provide some pointers that might help you understand what is happening.
Firstly, I would suggest taking a look at the binding docs - at the end there is a section called something like “what to do when things don’t go as planned”. This will tell you how to configure the logging - this is important as you will be able to see what is failing, and then hopefully you can adjust your Xbee code to fix this.
It’s also important to understand that the ZigBee binding uses the ZigBee protocol - this is not necessarily the same as Xbee. The binding expects features such as the different descriptors to be supported (as required by ZigBee) so that it can discover the features in the device.
Once you have logging working, then you can use the log viewer here -:
Now what the binding will do is to download the descriptors - one of which (called the SimpleDescriptor) will describe the features of an endpoint - the server and client clusters supported etc. The binding will evaluate this to find clusters that it knows how to support - it will try and read back attributes to work out how to support them, and will then present these to the user as channels.
It seems from the error above that either your device isn’t returning this descriptor, or it is not reporting clusters correctly, or simply that the clusters supported do not provide any of the standard features that the binding supports. I don’t know what you are implementing here, so it is very difficult to say too much more.
Thank you for your answer, it provides me indications and keywords in order to go further.
As you say, I think that the issue is located on the end device, which is not sending the informations needed by the binding in order to set up correclty the communication.
This morning, I was able to connect through SSH to the OpenHab console and activate DEBUG logs. Then, the idea is to check what the log says when I have the “No supported clusers found”, and look for any RX frame. This will confirm that the end-device is sending something, but which is not recognized by the binding.
Probably this will not help you since the descriptors will have been downloaded much earlier during the discovery phase. You may need to rediscover the device, and then look at the log of the discovery.
Hmmm - you might need to read up on how ZigBee works. If you’re creating your own device, and you are not able to answer this very fundamental question, then you should look for a crash course in ZigBee on the web
Clusters are kind of functional blocks within the interface - eg there is a cluster for turning devices on or off, another for color control, another for alarm related functions etc.
If you don’t support any clusters (and you don’t) then your device doesn’t do anything.
Well, it is not reporting that it supports any clusters - as above, that means it doesn’t do anything. This might be correct and the device is not programmed to do anything, or it might be that something is wrong. I really don’t know as I’ve no visibility of how you’re programming your device.
