Since the reinstall of openhab, I have not been able to use the connect to xbmc on both my tvs.
the port 8080 is accessible via the web browser but I am not sure about the 9090 port.
These are the settings enabled in kodi, webserver is on with allow remove control via http. remote control has both the options active to control by program on this system as well as other systems.
edit: rebooted raspberry pi, openhab and both the tv boxes and it seems to be working now.
my ports seem to be correct - but i get an error message in the log file:
18:46:41.218 [DEBUG] [binding.xbmc.rpc.XbmcConnector:191 ] - [192.168.1.20]: Websocket opened
18:46:42.586 [ERROR] [enhab.binding.xbmc.rpc.RpcCall:153 ] - Error handling POST response from XBMC
org.openhab.binding.xbmc.rpc.RpcCall$RpcException: {code=-32601, message=Method not found.}
at org.openhab.binding.xbmc.rpc.RpcCall$1.onCompleted(RpcCall.java:145) ~[bundlefile:na]
at org.openhab.binding.xbmc.rpc.RpcCall$1.onCompleted(RpcCall.java:1) ~[bundlefile:na]
at com.ning.http.client.AsyncCompletionHandler.onCompleted(AsyncCompletionHandler.java:63) ~[async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyResponseFuture.getContent(NettyResponseFuture.java:292) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyResponseFuture.done(NettyResponseFuture.java:319) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.markAsDone(NettyAsyncHttpProvider.java:1521) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.finishUpdate(NettyAsyncHttpProvider.java:1538) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.access$2600(NettyAsyncHttpProvider.java:158) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider$HttpProtocol.handle(NettyAsyncHttpProvider.java:2188) [async-http-client-1.8.4.jar:na]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.messageReceived(NettyAsyncHttpProvider.java:1220) [async-http-client-1.8.4.jar:na]
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.http.HttpClientCodec.handleUpstream(HttpClientCodec.java:92) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [netty-3.9.0.Final.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [na:1.8.0]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [na:1.8.0]
at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
18:46:42.581 [ERROR] [enhab.binding.xbmc.rpc.RpcCall:153 ] - Error handling POST response from XBMC
