I’m just getting started now with OH2 and struggling a little in where/how to set things up regarding the bindings and their cfg.
So… A fresh install of OH2 and my /conf/services/addons.cfg is still set for demo.
In the paper ui, under extensions/bindings, I installed the xbmc addon But now I really don’t know where to proceed. When I click on bindings, I do not see that listed. And I do not see any xbmc.cfg file in the conf/services folder.
Do I need to change the addons.cfg from demo to standard and manually list out the binding names? Or create a separate xbmc.cfg file?
Also… I’m sure someone has mentioned it. But perhaps beginning with OH2, should the binding name be changed from xbmc to Kodi?
I took a day to play with OH2, but I also couldn’t make heads or tails of this, I couldn’t get any of my bindings working except the dmx binding seemed to work out of the box. maybe try here
Meanwhile, you can simply create a xmbc.cfg entry yourself in conf/services with entries according to the XBMC wiki (but stripping off the “xbmc:” prefix on the parameters.
I created the bug report that the cfg file is not being generated when installing the binding.
And I have gone and manually added an xbmc.cfg file to my conf/services location as well as added my xbmc items and can confirm the binding is working.
But I did notice the paper ui does not show the ability to add any xbmc items and not sure if it suppose to or not. But by adding them manually to the items file and site map, I can confirm the binding does work.
No, the Paper UI does not know anything about 1.x add-ons apart from the fact that it supports installing them.
You have to keep using it as before with creating item files etc.
Thanks for testing, good to know that it works!
I think you also need to ensure your the username and password within the ‘webserver’ in xbmc is set to match what you put in your config file.
I was also curious if there were any plans to possibly rename the binding to Kodi going forward?
This is my xbmc.cfg file. I believe all that is different from using it in OH1 is just removing xbmc: from the beginning of each item
# Hostname / IP address of your XBMC host
FamilyRoom.host=192.168.11.52
# Port number for the json rpc service (optional, defaults to 8080)
#FamilyRoom.rsPort=8080
# Port number for the web socket service (optional, defaults to 9090)
#FamilyRoom.wsPort=9090
# Username to connect to XBMC. (optional, defaults to none)
FamilyRoom.username=xbmc
# Password to connect to XBMC. (optional, defaults to none)
FamilyRoom.password=xbmc
Have copied all the above, but the log file does not even mention it anywhere. There was no XMBC Binding as mentioned above, so I just added it manually to the openhab.cfg file. Is that right?
I did as Kai suggested and removed the xmbc prefix, and have done the settings etc inside of Kodi but getting nowhere with this.
Anyone got any more help or have done this recently and could show anything would be much appreciated.
Which version of OH are you using? For OH2, you need to enable the binding via the PaperUI. But OH2 currently does not create the cfg file, so you just need to create that separately.
Have altered the relevant settings inside Kodi to allow other programs etc.
Added the xbmc prefix in front of each.
modified the IP to where Kodi is running (Fire Stick).
Have run a apt-get update, upgrade and reboot after modifying.
It is not even attempting to connect, the Log File shows nothing, and even the txt log file is empty.
I am thinking it has to do something with the fact that the binding for xbmc is not on the .cfg file, would you think that could be a reason.
Kai mentioned it earlier, the fact that it was not on the current versions.
Not sure how or why - But last night was still nothing, but I just ran another reboot and upgrade and now its connected and working.
I am now able to stop whats playing - and it displayed the Title of the Radio Station / Track we had going - I used the Stop button and that stopped it.
Just trying to get it to play something now from within OH - But a huge improvement on where it was.
Any idea on how I use it to Navigate, or set it to come on etc? Can Pause, Play and Stop whats playing - But struggling to open or browse for something.
I can confirm that this is working for Kodi instance installed through Retropie on a Pi3. The only issue so far is some odd sitemap renderings, but have not spent any time on the sitemap other than quick setup for validation.
Hi… I understand that I am reviving an old topic.
I am beginning my journey with Openhab and I chose OpenHab2. I can’'t get the XBMC service to appear in PaperUI.
The binding version I installed through the paper UI is version 1.9.0 SNAPSHOT. Then I went into /opt/openhab2/conf/services and edited the xbmc.cfg file to look like this
# Hostname / IP address of your XBMC host (required). Example:
livingRoom.host=192.168.1.7
# Port number for the json rpc service (optional, defaults to 8080). Example:
livingRoom.rsPort=8080
# Port number for the web socket service (optional, defaults to 9090). Example:
livingRoom.wsPort=9090
# Username to connect to XBMC. (optional, defaults to xbmc). Example:
livingRoom.username=kodi
# Password to connect to XBMC. (optional, defaults to xbmc). Example:
livingRoom.password=
#Refresh interval in ms (optional, defaults to 60000ms [1 minute])
refreshInterval=60000
I can access the Kodi at 192.168.1.7:8080 (not authentication needed) so, I have already tested with
livingroon.username=
and
livingroon.username=kodi
Then I have also restarted both systems (openelec and openhab running on different RPi)
What do I need to do to get this working?
PS: I haven’t figured out a sitemap yet (it’s still too complex for me) so, do I need to do something about the "livingroom"
Please help
Most (probably all) of the legacy 1.9 bindings require you to manually create the items in your items file and then add them to a SiteMap. Below is are the XBMC items I have configured.
