XBMC to play TV list Channels
Hello All,
Im new to openhab, and i was trying to build a connection to my XBMC, which has a streaming channels playlist.
I used the send the below http request to change the channel:
http://xbmc_ip/jsonrpc?request={“jsonrpc”:“2.0”,“id”:1,“method”:“Player.Open”,“params”:{“item”:{“channelid”:213}}}
This works perfectly from the browser.
I wanted to the same with xbmc binding in opemhab but i failed to do that with “playeropen” property.
The only example i saw was sending an url to the Player.Open property to be played.
Could you help me in formatting the same command as the http command with xbmc binding?
Thanks all in advance
