Xiaomi Aqara Human Motion Sensor - how to get graph working?
Will do thanks @vzorglub
Do you know the command to check how large the database is?
… and also, do you export the data to your openhab (basicUI or habPanel)?
When I try to share my graph, I get a link that looks like this:
http://ip:3000/render/d-solo/sOu_M3Zgk/xiaomi-lux-sensors?refresh=1h&orgId=1&panelId=4&from=now-48&to=now&width=1000&height=350&tz=UTC%2B01%3A00
I’m not able to edit it so it works in basicUI - also when using the frame in the habPanel I get the whole graph + the posibility to edit the settings.
I don’t use basic ui.
I use the frame in Habpanel and you can tell grafana to make the dashboard non-editable.
There is also a way to disable clicks on frames with a bit of code in the frame but I haven’t looked into it yet.
I only checked the database size once and I can’t remember the size. I googled it at the time.
@vzorglub sounds good :).
How does your link look like in habpanel? The one used in the frame?
Yes exactly the same
Okay :slight_smile: Seems to be working just fine :).
To get the size of the influxdb database:
cd /var/lib/influxdb/data
sudo du -sh openhab_db
where /var/lib/influxdb/data is the data directory defined in influxdb.conf.
Mine after 3 month is 4.7M
That’s 20M/Year
But it will depend on how many items you have and how often they are updated of course!
Yes! Works brilliant!
Haha, then the size doesn’t gonna be a problem on your end :stuck_out_tongue:
