Did anyone got Xiaomi Aqara LED to run with ConBee2 Gateway? Any guideline?
Finally I can setup the LED light with ConBee2 but it is still not supported by openHAB2 bindings.
How to:
Just enter http://localhost:80/pwa and start searching for light. Normally, Xiaomi Aqara LED ZNLDP12LM resets if 3x ON/OFF cycled. Light will blink if it is successfully reseted and will start searching for Zigbee GW. I needed to repeat the steps more than five times and always run scan for 3 min but finally the light was there. I have no systematic way to find the light yet but maybe someone else know how to.
Now I try get the light in openHAB but I think I need your help.
I tried Xiaomi MI IO Binding in Paper UI. There is a Xiaomi Device in the Inbox but it asks for a Token. I do not know how to find out the token so maybe you can help me out here. If I have the Token I think I can connect the lights in Paper UI.
I also tried deCONZ binding and was looking for an option to connect to the light but there is no obviouse ay to connect light in generall.
Thanks for this post it clearly save me
I’ve the same setup as you:
- Phoscon ConBee 2
- Openhab 3
- DeCONZ bindings
- Xiaomi Aqara LED ZNLDP12LM
I’ve successfully pair my Xiaomi Aqara LED to Phoscon Conbee 2 by repeating the procedure 3 times:
- Attempt to descover ligth for 3 minutes from the Phoscon Conbee2
- Switch on-off 3 times the ligth and get the 2 blinks say it enter in a Pairing mode
The time when it worked I’ve 1 more blink from the light, then when the Phoscon Conbee 2 pair it I’ve got 3 blinks more.
Then, Openhab side, I’ve got the item in my inbox like all others.
May I can notify the Phoscon company that it’s work even if they says not
Thanks again for your post @P4trick it helped me a lot !!!
I’ve respond to you with lot of keyword to help Google find this post more easily
