Ok, then I use neutral terms. Bring the transmission partners close together, that structual conditions for interference can be eliminated. This first step is mandatory for all over the air transmission debugging to make sure that there is no environmental reason for malfunction.
I already wrote that I sit pretty close to the USB Stick. I’m not the only one with exact problem like that: Xiaomi Temperature and Humidity Sensor
I tried to use zigbee2mqtt instead of the zigbee binding. zigbee2mqtt gives me all informations. That means, the binding maps the informations wrong.
