Hi, I’m trying to make the Xiaomi Binding work within a docker-compose container.
In order to do it, I’ve added the following lines in the service definition:
network_mode: “host”
ports:
- 9898:9898/udp
- 9898:9898/tcp
Using paper-ui I can add the binding and things.
Registered the right developer key.
Initially, all the things look online but after a while (timeout), they become off-line except for the Xiaomi Mi Smart Home Bridge that it still online.
Trying to send a command to the gateway I get the following error:
2018-08-10 12:42:23.735 [WARN ] [g.mihome.handler.XiaomiBridgeHandler] - No token received from the gateway yet. Unable to encrypt the access key.
2018-08-10 12:42:23.738 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.mihome.handler.XiaomiActorGatewayHandler@44cae98c’: null
Inside the container, I’ve tried to sniff the 9898 port and it happens it can get the messages from the Xiaomi gateway, as expected:
tcpdump -A -s0 -vv port 9898
tcpdump: listening on enp3s0, link-type EN10MB (Ethernet), capture size 262144 bytes
12:33:38.853621 IP (tos 0x0, ttl 255, id 2283, offset 0, flags [none], proto UDP (17), length 163)
lumi-gateway-v3_miio78xxxxxxx.station.4321 > 224.0.0.50.9898: [udp sum ok] UDP, length 135
E..........q.......2..&....J{"cmd":"heartbeat","model":"gateway","sid":"xxxxxxxxx","short_id":"0","token":"3kLRUHiqZtzPIPfU","data":"{\"ip\":\"192.168.1.xxx\"}"}
Inside the same network, another non-docker installation of openHAB works as a charm: sends commands and receives data.
I guess, the problem is which interface the binding, through openaHAB, is watching.
How can I specify which interface the binding should use to listen on 9898?
