I’m not new to openhab, I have been using it for a while now. But I want to start making rules. First ones work oke, but this one is a little more complicated.
I want to switch on a light in the laundry when the door opens and switch it off when the door is closed. Like the light in the fridge:)
I tried the following code using visual studio code:
rule “Washok Licht aan/uit”
Channel “WashokDoorSensor_OpenStatus” triggered START
sendCommand(FF_Switch_Washok_Switch, ON)
But nothing happens. Does someone could help me out?
Why do you use channel to trigger. Doesn´t your door sensor have an item?
I believe this is what it could be like:
rule "Washok Licht aan/uit"
Item <door sensor item> changed
if(<door sensor item>.state == ON) {
FF_Switch_Washok_Switch.sendCommand(ON)
logInfo("info", "door sensor is open")
else
FF_Switch_Washok_Switch.sendCommand(OFF)
Notice if the door sensor reports ON/OFF or OPEN/CLOSED. If it reports OPEN/CLOSE, then you´ll need to change the arguments. (normally a door sensor will report OPEN/CLOSE).
